zebo51 22 Posted January 12, 2022 Posted January 12, 2022 Right now my biggest folder is media\Movies (Bluray)\Moviename (year)\moviename.year.filetype If I were to move everything into folder letters to make it easier to maintain will I loose all my watched/played statuses etc? Images, nfo etc are all stored in the associated movie folder. media\Movies (Bluray)\0\Moviename (year)\moviename.year.filetype media\Movies (Bluray)\A\Moviename (year)\moviename.year.filetype media\Movies (Bluray)\B\Moviename (year)\moviename.year.filetype etc If so, anyway to do this to keep the played status or least painful way to make this transition? Thanks
Solution Happy2Play 9802 Posted January 12, 2022 Solution Posted January 12, 2022 Emby tracks that played state by providerid not path so moving media is not a issue. Only items with no providerids will lose status as there will/are track by a custom db id that gets deleted when moved. Other option is manually updating database and library files.
zebo51 22 Posted January 14, 2022 Author Posted January 14, 2022 On 1/12/2022 at 2:19 PM, Happy2Play said: Emby tracks that played state by providerid not path so moving media is not a issue. Only items with no providerids will lose status as there will/are track by a custom db id that gets deleted when moved. Other option is manually updating database and library files. Great it worked. I did have a few that showed back up as not played but not a big deal on those. So what is the provideredid and is that something that can be seen in the GUI or stored somewhere accessible? Thanks
Happy2Play 9802 Posted January 14, 2022 Posted January 14, 2022 1 minute ago, zebo51 said: So what is the providerid and is that something that can be seen in the GUI or stored somewhere accessible? It would the TMDB, TVDB, IMDB ids and yes you can see these per item.
zebo51 22 Posted January 14, 2022 Author Posted January 14, 2022 16 minutes ago, Happy2Play said: It would the TMDB, TVDB, IMDB ids and yes you can see these per item. Oh yeah I know those IDs in the meta data. Thanks
