Hellfire84 1 Posted January 12, 2022 Posted January 12, 2022 I have a conversion running that's setup to replace original files with converted files, as well as automatically convert new files. I'm thinking of trying Unmanic for more control over conversions, but it seems like the only removal option under 'Conversion' tab removes downloads, which I'm assuming would remove that Conversion as well as all converted files. Am I correct? Does removing the Conversion trigger the removal of all converted files? The KB shows how to setup a conversion, but not how to cancel or remove a conversion once created.
Luke 42246 Posted January 12, 2022 Posted January 12, 2022 Hi, that will only remove the job, not the files.
Hellfire84 1 Posted January 12, 2022 Author Posted January 12, 2022 Hi Luke, Awesome, seemed awkward to remove the files, but was confusing. I really appreciate Emby and your support. I've become a huge fan. Have a great rest of your day!
