technick90 3 Posted January 11, 2022 Posted January 11, 2022 (edited) DS415+ DSM 7.0.1-42218 Emby 4.6.7.0 Hello, Right now I have two problems. 1) I cannot currently save any settings changes. The circle goes round, but nothing happens. If I make the changes manually in the config file, they will be adopted. 2) I have several .avi files. I can play these with the Android app on the smartphone. This is not possible on the FireTV or a Samsung TV. For the log file, see the appendix. Best Regards Robert ffmpeg-transcode-3fcfe946-32f1-46c2-920b-d3d94dac0d98_1.txt embyserver.txt Edited January 11, 2022 by technick90 embyserver.txt uploaded
Luke 42243 Posted January 11, 2022 Posted January 11, 2022 Hi there, please attach the main emby server log as well. thanks.
technick90 3 Posted January 11, 2022 Author Posted January 11, 2022 main log was uploaded. I converted the .avi to .mkv. Now I can play the files. But I don't know why .avi does not work.
Carlo 4561 Posted January 11, 2022 Posted January 11, 2022 AVI files with mpeg4 have more or less been dead for years as they are not a streaming format.. There's not a lot of hardware that will play these files so the Emby Server needs to convert them on the fly. Computers, tablets and phones are a bit more flexible in what they can play. When you converted it to MKV you created a file that is now in a format that can be streamed so results will be a lot better. Your log shows an error when trying to convert the file which is something we can take a look at and maybe handle better in the future. I doubt many people still use a lot of AVI files so we likely haven't seen this before until now. @softworkz Can you take a look at the ffmpeg log file and see if this is something we could address?
technick90 3 Posted January 12, 2022 Author Posted January 12, 2022 @cayars Thanks for the explanation. Don't have a lot of avi files anymore. I'll just convert them all. Does anyone have an idea why I can't save any more settings?
technick90 3 Posted January 12, 2022 Author Posted January 12, 2022 For example access rights from user, which device is allowed for this user.
Luke 42243 Posted January 12, 2022 Posted January 12, 2022 The server is being denied access to write to it's own data folder: 2022-01-11 17:26:48.081 Error App: Error deleting file /var/packages/EmbyServer/var/cache/images/resized-images/1/17078c62-05a5-398b-6611-d1dab99462ce.png *** Error Report *** Version: 4.6.7.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 3.10.108 (root@build15) (gcc version 7.5.0 (GCC) ) #42218 SMP Mon Oct 18 19:16:10 CST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/var/packages/EmbyServer/var/cache/images/resized-images/1/17078c62-05a5-398b-6611-d1dab99462ce.png' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileSystem.DeleteFile(String fullPath) at Emby.Server.Implementations.ScheduledTasks.Tasks.DeleteCacheFileTask.DeleteFile(String path) Source: System.IO.FileSystem TargetSite: Void DeleteFile(System.String) InnerException: System.IO.IOException: Permission denied Source: TargetSite: Did you by any chance just update from a really old version? @cayars
technick90 3 Posted January 12, 2022 Author Posted January 12, 2022 I always kept the system up to date. And recently I carried out the update from DSM 6 to DSM 7. But I think I remember having completely reinstalled emby for this. No update went. And I don't know anymore whether the data was then automatically adopted or whether I had to adjust something. Can I somehow make a backup, reinstall and import a backup? In the hope that he then sets the permissions correctly.
Carlo 4561 Posted January 12, 2022 Posted January 12, 2022 How long ago was it when you did the DSM 6 to 7 upgrade? Do you still have the DSM 6 version on your system which is normally located at /volume1/Emby assuming you only have one volume. It could be /Emby off another volume as well. If you had to reset up things are you currently missing any information you wish you had? IE watched status or users? I ask because it's still possible to re-migrate the data again if your original source is intact. But it may or may not make sense depending on your current state. Redoing the migration could fix the permission issues or we could fix the current DSM 7 install permission issues. Do you have a preference? Or would one be better than the other? I could remote in and give you a hand with this either way.
technick90 3 Posted January 12, 2022 Author Posted January 12, 2022 I made the upgrade about 4 weeks ago. The library, the users and the viewed status are required. So actually everything. Migrating again is bad, after that there were definitely changes to the viewed status. If you can do this remotely, that's a great service. But I can certainly do it alone, as I am an IT specialist. The question is what should the permissions look like? See the appendix for the current status.
Solution Carlo 4561 Posted January 12, 2022 Solution Posted January 12, 2022 Shutdown emby then try this from SSH with sudo chown -R emby:emby /volume1/@appdata/EmbyServer That might be enough to get things working properly for you.
technick90 3 Posted January 12, 2022 Author Posted January 12, 2022 It worked. Thanks very much! That was almost too easy. I don't like to change owners / permissions without knowing that it is correct. So thanks for the support. 1
Carlo 4561 Posted January 12, 2022 Posted January 12, 2022 Glad to hear it and had my fingers crossed that would work for you as it's much easier/safer than starting to adjust individual read/write, group permissions!
