Brauco 0 Posted January 10, 2022 Posted January 10, 2022 I installed emby server to my android TV and no longer can I sign in. I cannot get this set up no matter what help I'm reading.
Luke 42239 Posted January 11, 2022 Posted January 11, 2022 Hi there, are you trying to connect to your own Emby Server, or someone else's Emby Server?
Brauco 0 Posted January 11, 2022 Author Posted January 11, 2022 I am trying to connect to my own emby server.
ebr 16332 Posted January 11, 2022 Posted January 11, 2022 17 hours ago, Brauco said: I installed emby server to my android TV Hi. You installed the server on an actual TV? Does the TV have access to any significant storage for your media? Which TV is it?
Brauco 0 Posted January 11, 2022 Author Posted January 11, 2022 I get an error saying wrong username or password.
Luke 42239 Posted January 14, 2022 Posted January 14, 2022 @Brauco are you able to login to your server web interface?
Alfa19 0 Posted January 19, 2022 Posted January 19, 2022 Amigo que más se puede hacer si no reconoce el ip
Luke 42239 Posted February 1, 2022 Posted February 1, 2022 @Brauco are you still having an issue with this?
Carlo 4561 Posted February 2, 2022 Posted February 2, 2022 11 hours ago, Brauco said: It has not been resolved. @cayars I'm sending you a private message to arrange a support session to get you some help.
Carlo 4561 Posted February 4, 2022 Posted February 4, 2022 I'm trying to fit two people in that shouldn't take too long. I'm hoping to remote in with you in a hour if that possible. Download and install TeamViewer from www.teamviewer.com. Send me the ID and one-time use password you get on launch. I'll connect and open a chat windows.
Brauco 0 Posted February 4, 2022 Author Posted February 4, 2022 Quick support gave me this ID 211 666 903
