BreakingNC 0 Posted January 9, 2022 Posted January 9, 2022 I had my main hard drive die today. It didn't store any of my movies, however it did store the server itself. Im having to setup a new hard drive with a fresh install. Is there a way to access my User and watch data or is it a complete loss? I am really hoping there is a way because I hate to start all over. Thanks
lorac 119 Posted January 9, 2022 Posted January 9, 2022 Did you use the sever configuration backup plug in?
BreakingNC 0 Posted January 9, 2022 Author Posted January 9, 2022 Unfortunately this is the first I have heard of it so im guessing not.
lorac 119 Posted January 9, 2022 Posted January 9, 2022 Not looking good then. You're certain the drive is toast?
BreakingNC 0 Posted January 9, 2022 Author Posted January 9, 2022 Oh yea bad sectors and completely dead. I work for a major computer company and was able to have several technicians look into it. Guess I will start from scratch. The good news is I didn't lose any of my content. I appreciate your help.
lorac 119 Posted January 9, 2022 Posted January 9, 2022 Make sure you install the server configuration backup plug in once you're setup again. 1
