zippy72 1 Posted January 8, 2022 Posted January 8, 2022 Hi, I recently upgraded my Emby through the TerraMaster App Store to version 4.6.7.0 (from a version old enough that the iPhone apps were complaining the server needed upgrading, if that helps). Since then I've noticed two strange problems, which I suspect are related somehow. The first is that a library that I deleted is still visible on the Apple apps (iPhone and Apple TV), even though it has disappeared from the web. On the apps, it appears to be an amalgamation of everything that exists in all the other libraries. The second is that a second copy of "Collections" has appeared in the main screen. The original "Collections" still has its original picture, but all the collections now say "[boxset]" after them, and clicking into them shows that they're empty. The second copy, which appears at the end, has a default picture (the pictures for the first four collections), and has all the original contents intact, even if some of the pictures I put on them have gone missing. I can still access the collections from the iPhone - a second "collections" button has appeared, so now I have one for each of the two collections. I'm unsure how to approach this. Unfortunately I upgraded more than five days ago, and there aren't any log files left from when the old library still existed, or when the upgrade was performed, so I haven't bothered uploading them, but I can if you feel they'll be useful. Have you seen this issue before? Any ideas on how to fix it? Thanks Simon @Happy2Play
Luke 42237 Posted January 9, 2022 Posted January 9, 2022 Hi @zippy72 do you know what version you upgraded from?
zippy72 1 Posted January 9, 2022 Author Posted January 9, 2022 Hi @Luke, Unfortunately I don't know of a way to find that out in Terra Master. I've had a look around the root file system to try and see whether I can find any log files for the app store, but so far I haven't as yet found any. Really all I know is as I said before - Emby for iOS 2.1.1 considered it too old. Simon
zippy72 1 Posted January 11, 2022 Author Posted January 11, 2022 OK, looking in the devices menu I think it's almost certainly version 4.5.2.0. Previous version prior to that was 4.4.3.0.
Happy2Play 9811 Posted February 5, 2022 Posted February 5, 2022 For Collections what do you see in Settings-Library for Collections? As for the iOS issue I have never heard of a device showing something different then the server for libraries. All i can think of is clearing the app/device cache for the client or maybe uninstalling the client and reinstalling.
zippy72 1 Posted February 10, 2022 Author Posted February 10, 2022 On 05/02/2022 at 03:00, Happy2Play said: For Collections what do you see in Settings-Library for Collections? As for the iOS issue I have never heard of a device showing something different then the server for libraries. All i can think of is clearing the app/device cache for the client or maybe uninstalling the client and reinstalling. The iPhone wasn't showing anything different, it was merely reflecting the double collections icons on the server. I ended up deleting the bad one and moving the good one and that worked for about a week. Then it broke again the other day, then spontaneously fixed itself last night. How, I have no idea. I've enclosed screenshots for what I see in the library settings, I don't know if there's any useful clues there?
Luke 42237 Posted February 15, 2022 Posted February 15, 2022 Can we please look at a specific example? Thanks.
