ChaoOos 2 Posted January 8, 2022 Posted January 8, 2022 Hello guys, I've been trying to connect my Fire TV Stick to Emby from outside my network for a few days now. The issue has been raised many times here in the forum, but none of the solution has helped me. It's because of the certificates. I have a Synology and have verified my domain with Let's Encrypt. I can download this certificate and I get 6 PEM files. 3x ECC, 3xRSA Using OpenSSL I concatenate the RSA PEM files into a .p12 file with password and store it with Emby. openssl pkcs12 -export -out embycert_RSA.p12 -in RSA-cert.pem -inkey RSA-privkey.pem -certfile RSA-chain.pem -passin pass:passwort -passout pass:passwort The site https://whatsmychaincert.com/ tells me that my chains are ok for my domain, but when I add port 8920 it tells me that it would have expired. iPhones and Android smartphones work. Only the FireTV Stick does not. Am I doing something wrong here already? I read that I need another chain certificate. Where do I get one and how do I link them to my files? Thx 4 your help
Solution ebr 16337 Posted January 8, 2022 Solution Posted January 8, 2022 Hi. the beta release of the app should solve this for you.
ChaoOos 2 Posted January 8, 2022 Author Posted January 8, 2022 3 hours ago, ebr said: Hi. the beta release of the app should solve this for you. You are my hero!! At least for a week 3 days search and try (OpenSSL, adb..) this is the best and easiest solution.
