DHos 1 Posted January 7, 2022 Posted January 7, 2022 I have some DVDs (not Blu-ray) that are a direct rip with no additional encoding. One direct plays but drops many frames causing some jerkiness. A couple others transcode (this is my home setup). Transcode reason being "ContainerBitrateExceedsLimit". While playing through Emby Theater, the quality setting will only let me choose 480p-4Mbps. All that I have tried are over that limit; around 5-7Mbps. I tried other DVD rips and as long as the codec was other than MPEG2 (h264, for example) no problems. Are there any settings I can change to fix this? Thanks
Luke 42197 Posted January 7, 2022 Posted January 7, 2022 Hi, try setting your quality setting in the app settings prior to playback and see if that helps. Thanks.
DHos 1 Posted January 7, 2022 Author Posted January 7, 2022 The spp already has quality maxed (480p-4Mbps).
Luke 42197 Posted January 7, 2022 Posted January 7, 2022 2 hours ago, DHos said: The spp already has quality maxed (480p-4Mbps). Hi, the app settings allow you to go much higher than that. Can you please try setting your quality setting in the app settings prior to playback and see if that helps. Thanks.
