Drazgo 8 Posted September 16, 2014 Posted September 16, 2014 I posted this awhile back but not sure if it was under a feature request. MB3 has grown to 7.5 GB on my SSD, mostly do to collection data housing, images, etc. Collections folders under /appdata/MB-Server is around 3 GB and the data folder is around 3 GB. I have updated paths in MB server for images and caching but Collections still seems to be there... is there a way we can get more control over where these reside? I'd like to keep MB on the SSD for application running purposes but its data growth I would like to allocate to a data drive. Thanks! Draz 1
Happy2Play 9812 Posted September 16, 2014 Posted September 16, 2014 The only Collection folder I have is inside the data folder from the auto-boxset plugin. Are you saying you have a Collection folder in (MediaBrowser-Server)? I would request that be moved to the cache folder instead of data folder.
ebr 16336 Posted September 16, 2014 Posted September 16, 2014 The only Collection folder I have is inside the data folder from the auto-boxset plugin. Are you saying you have a Collection folder in (MediaBrowser-Server)? I would request that be moved to the cache folder instead of data folder. That information is not cache, it is data so it is in the proper place. However, it is reasonable to ask that its location be configurable like some of the others. 1
Drazgo 8 Posted September 18, 2014 Author Posted September 18, 2014 Found the original link just for reference: http://mediabrowser.tv/community/index.php?/topic/8365-auto-box-sets-how-to-change-collection-metadata-path/ Cheers!
