mike3821 67 Posted January 6, 2022 Posted January 6, 2022 What variables are passed into the .sh script file. $1 means the filename correct? What is the path variable?
Luke 42246 Posted January 6, 2022 Posted January 6, 2022 hi, {path} is the path to the recording file, so you want "{path}" to be in the command line arguments somewhere. Most likely the default should be fine.
mike3821 67 Posted January 6, 2022 Author Posted January 6, 2022 Okay so a simple /usr/bin/comskip --ini /etc/comskip.ini $1 > /dev/null Will that work?
