RG9400 0 Posted January 6, 2022 Posted January 6, 2022 (edited) I'm not sure exactly how to reproduce it. I've noticed this behavior for years now though. I have Emby Premiere, and I set both Theme and Settings Theme to Dark. Theme remains applied over time, but I keep noticing Settings Theme resetting to Light. I'm not sure if it happens only after updates as I can't reliably reproduce it, but it happens enough that I've noticed over the last 2-3 years. I know it's not a super useful report, but I wanted to create a topic in case anyone else has experienced it and can give some more data points, or at the very least just to inform the dev team about it. EDIT: It also seems like the "Enable Backdrops" setting resets as well Edited January 6, 2022 by RG9400
Luke 42241 Posted January 6, 2022 Posted January 6, 2022 Quote EDIT: It also seems like the "Enable Backdrops" setting resets as well Hi, for this, it sounds like something is clearing browsing data, as this is stored in the client app that you're browsing from. Either that or there is another user changing the option on the same device.
RG9400 0 Posted January 6, 2022 Author Posted January 6, 2022 That will be it, I guess I didn't realize since the regular Theme option stays on Dark.
