T800 10 Posted January 4, 2022 Posted January 4, 2022 I've noticed on the dashboard that active devices outside the home network don't give me the option to press stop. Can this be changed?
ebr 16309 Posted January 4, 2022 Posted January 4, 2022 Hi. Remote control of remote devices is not always possible and the application reports when it isn't and, thus, don't show you this option. 1
T800 10 Posted January 4, 2022 Author Posted January 4, 2022 Hi. Thanks for the reply. My understanding of such things is way below yours, can you tell me why the server isn't just able to cancel the stream?
ebr 16309 Posted January 4, 2022 Posted January 4, 2022 26 minutes ago, T800 said: can you tell me why the server isn't just able to cancel the stream? Hi. That would be a different operation than the one currently implemented. That has been requested before though. 1
