Ikario 39 Posted January 4, 2022 Posted January 4, 2022 Transcoding used to work before this version. After updating, it does not. Using a docker container (linuxserver image because official image did not work properly back when I tested it) on a QNAP TVS-872XT with a Quadro P2200 and an i7-8700t. SSH'd into the container. Nvidia drivers are there, /dev/dri is there. Everything is detected properly inside Emby, both Quicksync AND the NVIDIA card. Transcoding is not working though, neither hardware NOR software transcoding, no matter what you are using to transcode. Changing from latest branch to beta branch and updating to 4.7.0.19 fixed the issue. I'd rather not be in the beta branch though, if possible. ffmpeg-transcode-096643ab-762d-4b0b-b6b8-70a066e6a5ac_1.txt
Luke 42240 Posted January 4, 2022 Posted January 4, 2022 Quote Changing from latest branch to beta branch and updating to 4.7.0.19 fixed the issue. Hi, thanks for the feedback. That's a good sign that it's resolved for the next release.
