Nastream 5 Posted January 3, 2022 Posted January 3, 2022 Hello, I have a display bug top250 in serie and movie when I add it to my favorites It shows top250 # 1 on all series movies this happens every time I bookmark a movie or series can you see if you can fix it? thank you @Équipe B
TeamB 2440 Posted January 3, 2022 Posted January 3, 2022 It looks like you are using extra skins and addons, without that info i can not reproduce what you are seeing. I also need more info on how to reproduce, you mention favourites, how are you doing that
Nastream 5 Posted January 4, 2022 Author Posted January 4, 2022 hello thank you for your feedback I am using the Titan BINGIE MOD v2.0.3 skin , and i dont use any addon syle trakt or themoviedb helper. For exemple : Dexter is not in my favorites for the moment : i have good rating : for exemple TOP 250 #57 : OK And now im add in my favorites (whether with embycon or with the emby phone application) in the example I added to favorites , now watch the top250 passed on # 1 My favorites is here : EmbyCon : Global Lists : TV Shows and : TV Shows-Favorites it doesn't matter if it's tv shows or movie, if I put in favorites it will display the TOP250 # 1 that I add to favorites from the embycon or from the app.emby.media/ or from the phone application it displays top250 # 1 (sorry for my english im use google trad)
Solution TeamB 2440 Posted January 4, 2022 Solution Posted January 4, 2022 I have no idea how to set this skin up, I tried for 30 min or so and can not work out how you get the view you do above. having said that I think I found the issue: https://github.com/faush01/plugin.video.embycon/blob/0a3023770a3e621c5d352c379e164a0ecac9c22e/resources/lib/item_functions.py#L567 For some reason I set the info_labels["top250"] = "1" for favorite items, this has been in there from the beginning (years) so I dont remember why was done like this, I can remove it in the next release.
Nastream 5 Posted January 5, 2022 Author Posted January 5, 2022 thank you very much, @Équipe B ils ok with last bêta
