Daniel9085 0 Posted January 3, 2022 Posted January 3, 2022 i bought a mi box s recently to replace my old streamer and installed emby as the media server since that i've had a small problem with the audio pass-thru option in the playback settings when the audio is set to auto in the mi box the Audio options appear in the emby playback settings and audio gets passed to my reciver Denon avr-1911 but only Dolby Audio when i try to start a movie with DTS or DTS-HD the player just crashes back to the movie play screen when i change the audio options in my mi box to manual DTS suddenly plays but again not DTS-HD, and if i restart my mi box the Audio Options in playback settings go away and no audio gets passed untill i change the mi box Audio setting back to Auto this problem is fixed if i use an external player like vlc which passes through every audio codec to my reciver no problem but i would still like to use the emby player i hope this is somewhat understandable english is not my first language
ebr 16337 Posted January 3, 2022 Posted January 3, 2022 Hi. Exactly how is everything hooked together?
Daniel9085 0 Posted January 3, 2022 Author Posted January 3, 2022 12 minutes ago, ebr said: Hi. Exactly how is everything hooked together? The mi box is connected via hdmi to my reciver and the reciver is connected to the tv
ebr 16337 Posted January 3, 2022 Posted January 3, 2022 6 hours ago, Daniel9085 said: when i try to start a movie with DTS or DTS-HD the player just crashes back to the movie play screen Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
Daniel9085 0 Posted January 5, 2022 Author Posted January 5, 2022 (edited) 16 hours ago, Luke said: @Daniel9085 ? sorry for not posting yesterday had a busy day didnt have any time to use the tv i tried enabled the debug option and then went to the play a file with a dts sound track but i there was no option to send a log from the playback screen because the video wont play at all i made a little video and uploaded it to youtube so you can better undestand what im talking about if i disable dts and dts hd pass-thru in the playback option the video will play but with stereo sound only Edited January 5, 2022 by Daniel9085
ebr 16337 Posted January 5, 2022 Posted January 5, 2022 4 hours ago, Daniel9085 said: but i there was no option to send a log from the playback screen because the video wont play at all Hi. You can send the log from the home screen user menu after causing that playback failure. Thanks.
Daniel9085 0 Posted January 5, 2022 Author Posted January 5, 2022 log sent at 9:44 utc -5 User was Daniel Tried playing The Post with DTS-HD audio
ebr 16337 Posted January 5, 2022 Posted January 5, 2022 Can I please see the server log that goes with that app log? Thanks.
Daniel9085 0 Posted January 5, 2022 Author Posted January 5, 2022 these are the only logs i have from todays date embyserver.txt embyserver-63776937609.txt
ebr 16337 Posted January 5, 2022 Posted January 5, 2022 Is the client in a different time zone from the server? That server log ends several hours before this app log.
ebr 16337 Posted January 5, 2022 Posted January 5, 2022 Can you please re-enable these options and then see if the item plays? User policy for Daniel. EnablePlaybackRemuxing: False EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: False
Daniel9085 0 Posted January 5, 2022 Author Posted January 5, 2022 4 minutes ago, ebr said: Is the client in a different time zone from the server? That server log ends several hours before this app log. yes actually i just noticed its set to a different time zone to utc -8 and the app is set to utc -2 where i live i re enabled the options and tired streaming again this time the video worked but the server transcoded dts to dolby saying direct play error i send a log from the playback now instead of the app menu these are the updated logs if it helps in any way embyserver.txt ffmpeg-remux-88eecae0-378e-4f27-a2f7-8a251c05a3f4_1.txt
ebr 16337 Posted January 5, 2022 Posted January 5, 2022 The system is reporting support for DTS but it isn't working. The audio chain is throwing a "not implemented" error. Do you have the Android level audio option on "Auto" or have you manually set it to indicate which formats are supported? When you allow remuxing/transcoding, the system recovers from the above error. The complete playback failure you had was due to the options you disabled (see the text below those options).
Daniel9085 0 Posted January 5, 2022 Author Posted January 5, 2022 11 minutes ago, ebr said: The system is reporting support for DTS but it isn't working. The audio chain is throwing a "not implemented" error. Do you have the Android level audio option on "Auto" or have you manually set it to indicate which formats are supported? When you allow remuxing/transcoding, the system recovers from the above error. The complete playback failure you had was due to the options you disabled (see the text below those options). The Audio in android is set on auto when i change it to manual emby does play dts but dts-hd is being played as stereo but the problem with that is when i restart the mi box or plug it off the audio option in the emby playback settings goes away and it stops passing through all audio untill i change the audio in the android settings back to auto again vlc and any other external player plays all dts codecs prefectly fine
Luke 42245 Posted January 5, 2022 Posted January 5, 2022 Hi, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks.
