oinfud 0 Posted January 2, 2022 Posted January 2, 2022 (edited) I'm running Emby Server on a 2018 Macbook Pro 13" on MacOS 12.1. There are two small issues: - The Emby Server tray icon doesn't fit in visually with the other tray icons (which are all monochrome). - The Embery Server tray icon and the pop-up menu are blurry (especially visible on the menu item labels). I'm also including a screenshot of another tray menu for comparison. Edited January 2, 2022 by oinfud
Luke 42237 Posted January 10, 2022 Posted January 10, 2022 Hi, yes we're looking into this. Thanks for reporting.
Luke 42237 Posted September 12, 2025 Posted September 12, 2025 Hi, the tray icon for macOS arm64 will be in the upcoming 4.9 server release. Thanks.
