karbonade 1 Posted December 30, 2021 Posted December 30, 2021 I run Emby 4.6.7.0 on DSM 7.0.1 and I want to move the Emby log files to my /volume1 partition. I can see in the emby server dashboard that the default path is /var/packages/EmbyServer/var/logs. But I can find nowhere a possibility to change that. In the forum enties I find some info about this but that concerns older versions and it's not helping me out. so I hope any of you can help me out on this one.
Solution Happy2Play 9812 Posted December 30, 2021 Solution Posted December 30, 2021 Currently there is not option within Emby to change this path. Other topics talk about creating a symbolic link. On 9/21/2021 at 9:36 AM, Luke said: Hi, there is currently no option to configure this, but it's possible for future updates. thanks. 1
karbonade 1 Posted December 30, 2021 Author Posted December 30, 2021 Thank you Happy2Play for your quick response. I'll just have to wait and be patience.
Carlo 4561 Posted December 31, 2021 Posted December 31, 2021 Unless this was changed in Emby Server to allow you to specify a location the symbolic link method is the way to go!
karbonade 1 Posted January 5, 2022 Author Posted January 5, 2022 OK. I will try this out. Thanks for the info you all. 1
