Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 (edited) The downside .avi, .mpg and .divx don't play it just end up not playing or if have started a mp4 or mkv it end looping that previous played video that last played You can experiment and try adding avi, mpg and dixv to this line. <DirectPlayProfile container="mp4,mkv,mpeg,mpegts" audioCodec="mp3,ac3,aac,he-aac,pcm" videoCodec="h264,mpeg2video" type="Video" /> These files didn't try to transcode? If not try changing (<TranscodingProfile container="mpegts") to (<TranscodingProfile container="mp4") Edited September 21, 2014 by Happy2Play
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 (edited) Changing this (<TranscodingProfile container="mpegts") to this (<TranscodingProfile container="mp4") solve it now everything works Edited September 21, 2014 by SHSPVR
Luke 42239 Posted September 21, 2014 Posted September 21, 2014 Nice job. Please attach the final result so that it can be included in a future release.
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 (edited) removed attach file see new one Edited September 21, 2014 by SHSPVR
Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 The User-agent can probably be removed since <FriendlyName>Hopper with Sling\(.*</FriendlyName> made it work in this case.
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 (edited) Happy2Play, on 20 Sept 2014 - 9:49 PM, said:Happy2Play, on 20 Sept 2014 - 9:49 PM, said:The User-agent can probably be removed since <FriendlyName>Hopper with Sling\(.*</FriendlyName> made it work in this case. That turn out to be a bad idea after all end up have to restore that User-agent line. Edited September 21, 2014 by SHSPVR
Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 (edited) @@SHSPVR Can you try changing the user agent and modifying your friendly name. <HttpHeaderInfo name="User-Agent" value="xip" match="Substring" /> to <HttpHeaderInfo name="User-Agent" value="XiP" match="Substring" /> or maybe "XiP*" We know we can get this to work on Hopper with Sling (XiP813), but will it work on the other models? Edit could you remove the model named also. Need to try and make this for all models if possible. Edit2. Can you see if this work without a friendly name. A profile I saw on Plex just uses <DeviceDescription>Echostar Technologies</DeviceDescription> So it will take some testing to make this profile as vanilla as possible. Edited September 21, 2014 by Happy2Play
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 (edited) Happy2Play, on 20 Sept 2014 - 11:27 PM, said:Happy2Play, on 20 Sept 2014 - 11:27 PM, said: @@SHSPVR Can you try changing the user agent and modifying your friendly name. <HttpHeaderInfo name="User-Agent" value="xip" match="Substring" /> to <HttpHeaderInfo name="User-Agent" value="XiP" match="Substring" /> or maybe "XiP*" We know we can get this to work on Hopper with Sling (XiP813), but will it work on the other models? Edit could you remove the model named also. Need to try and make this for all models if possible. Edit2. Can you see if this work without a friendly name. A profile I saw on Plex just uses <DeviceDescription>Echostar Technologies</DeviceDescription> So it will take some testing to make this profile as vanilla as possible. Yes change it to XiP work the 2nd didn't at all So like this will be OK <Name>Hopper-Joey</Name> <Identification> <FriendlyName>Hopper</FriendlyName> <ModelNumber /> <SerialNumber /> <ModelName /> <DeviceDescription /> <ModelUrl /> <Manufacturer /> <ManufacturerUrl /> <Headers> <HttpHeaderInfo name="User-Agent" value="XiP" match="Substring" /> </Headers> </Identification> Here the XML Edited September 21, 2014 by SHSPVR
Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 Join the troubleshooting of the Hopper/Joey profile here. http://mediabrowser.tv/community/index.php?/topic/10477-dlna-with-dish-hopper-and-joey/
Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 Can you try without Friendly name. So in theory this will work on Joey also.
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 Sorry about that I did remove but end up back in file some so thing I manual edit it I let you know in about 10mins
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 (edited) Happy2Play, on 21 Sept 2014 - 12:43 AM, said:Happy2Play, on 21 Sept 2014 - 12:43 AM, said:Can you try without Friendly name. So in theory this will work on Joey also. So far yes it working with out any Friendly name even on Joey and Super Joey Edited September 21, 2014 by SHSPVR
Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 @SHSPVR - Great news can you post the final revision. And thanks for all the testing.
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 (edited) Final ver Edited September 21, 2014 by SHSPVR
Luke 42239 Posted September 21, 2014 Posted September 21, 2014 you need to add some identification criteria - friendlyname, model, etc. sometimes the http headers are used, sometimes the device properties. if they're all empty the profile will end up getting matched for every device.
Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 (edited) @Luke How is this? Updated xml. Dish Hopper-Joey.xml Edited September 21, 2014 by Happy2Play
Luke 42239 Posted September 21, 2014 Posted September 21, 2014 that looks good, although i didn't mean to suggest you had to fill out all those fields. so if you don't want friendly name + manufacturer + url, remove one or two. basically the rule of thumb is you want at least one device property, and at least one http header. that will cover both the dlna server and play to functions. so based on that let me know if this is the final one and i'll add it to MBS.
Happy2Play 9811 Posted September 21, 2014 Posted September 21, 2014 @Luke Update previous post. Removed friendly name.
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 (edited) Hmm Edited September 21, 2014 by SHSPVR
SHSPVR 125 Posted September 21, 2014 Posted September 21, 2014 Still works just fine stick with that. Should I start new post in ref to this below Now on to a few small problem I see which not really a big deal but not sure if it be on hopper end or possible on MBS end. Here just one Any way when ever I browser TV Series the sub folder listed to get to videos on Hopper or Joey and cancel (back page) it doesn't always list the same folder when first when there.
Happy2Play 9811 Posted September 22, 2014 Posted September 22, 2014 You would probably have to look at the server logs and see if there are errors when this happens.
SHSPVR 125 Posted September 23, 2014 Posted September 23, 2014 (edited) The only thing I see so far is just stuff like this 2014-09-22 15:31:21.7048 Error - DtoUtils: ServiceBase<TRequest>::Service Exception Event with Id uuid:d0648cd692304250b8f2613506dda094 not found. MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Dlna.Eventing.EventManager.GetSubscription(String id, Boolean throwOnMissing) at MediaBrowser.Dlna.Eventing.EventManager.RenewEventSubscription(String subscriptionId, Nullable`1 timeoutSeconds) at MediaBrowser.Dlna.Service.BaseService.RenewEventSubscription(String subscriptionId, Nullable`1 timeoutSeconds) at MediaBrowser.Api.Dlna.DlnaServerService.ProcessEventRequest(IEventManager eventManager) at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2014-09-22 15:31:21.7048 Error - HttpServer: Error processing request for /mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events Event with Id uuid:d0648cd692304250b8f2613506dda094 not found. ServiceStack.HttpError No Stack Trace Available 2014-09-22 15:31:21.7204 Error - NotFoundHttpHandler: 192.168.2.2:8096 Request not found: /mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events2014-09-22 15:31:21.7204 Debug - HttpServer: HTTP Response 404 to 192.168.2.46. Response time: 31.2001 ms. Url: http://192.168.2.2:8096/mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events2014-09-22 15:31:21.7360 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 6a2e050a2f4a4ac499dc8d202f13aa452014-09-22 15:31:22.1885 Debug - HttpServer: HTTP SUBSCRIBE http://192.168.2.2:8096/mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events Ip: 192.168.2.47:35103. Headers: HOST=192.168.2.2:8096,SID=uuid:7a5b374da46041bf94ea8350bb1985e4,TIMEOUT=Second-18012014-09-22 15:31:22.1885 Error - DtoUtils: ServiceBase<TRequest>::Service Exception Event with Id uuid:7a5b374da46041bf94ea8350bb1985e4 not found. MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Dlna.Eventing.EventManager.GetSubscription(String id, Boolean throwOnMissing) at MediaBrowser.Dlna.Eventing.EventManager.RenewEventSubscription(String subscriptionId, Nullable`1 timeoutSeconds) at MediaBrowser.Dlna.Service.BaseService.RenewEventSubscription(String subscriptionId, Nullable`1 timeoutSeconds) at MediaBrowser.Api.Dlna.DlnaServerService.ProcessEventRequest(IEventManager eventManager) at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2014-09-22 15:31:22.1885 Error - HttpServer: Error processing request for /mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events Event with Id uuid:7a5b374da46041bf94ea8350bb1985e4 not found. ServiceStack.HttpError No Stack Trace Available 2014-09-22 15:31:22.1885 Error - NotFoundHttpHandler: 192.168.2.2:8096 Request not found: /mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events2014-09-22 15:31:22.2041 Debug - HttpServer: HTTP Response 404 to 192.168.2.47. Response time: 15.6 ms. Url: http://192.168.2.2:8096/mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events2014-09-22 15:31:22.2041 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 12dfa72dd3b14d8ba8850a6c6aeabab52014-09-22 15:31:22.3289 Debug - HttpServer: HTTP SUBSCRIBE http://192.168.2.2:8096/mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events Ip: 192.168.2.48:56662. Headers: HOST=192.168.2.2:8096,SID=uuid:57cedb9436da48d5922d01d8745693a7,TIMEOUT=Second-18012014-09-22 15:31:22.3289 Error - DtoUtils: ServiceBase<TRequest>::Service Exception Event with Id uuid:57cedb9436da48d5922d01d8745693a7 not found. MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Dlna.Eventing.EventManager.GetSubscription(String id, Boolean throwOnMissing) at MediaBrowser.Dlna.Eventing.EventManager.RenewEventSubscription(String subscriptionId, Nullable`1 timeoutSeconds) at MediaBrowser.Dlna.Service.BaseService.RenewEventSubscription(String subscriptionId, Nullable`1 timeoutSeconds) at MediaBrowser.Api.Dlna.DlnaServerService.ProcessEventRequest(IEventManager eventManager) at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2014-09-22 15:31:22.3289 Error - HttpServer: Error processing request for /mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events Event with Id uuid:57cedb9436da48d5922d01d8745693a7 not found. ServiceStack.HttpError No Stack Trace Available 2014-09-22 15:31:22.3445 Error - NotFoundHttpHandler: 192.168.2.2:8096 Request not found: /mediabrowser/dlna/contentdirectory/dd3808bc7523eca1cafd3f722a8a8fb5/events Edited September 22, 2014 by SHSPVR
coldhammer 2 Posted March 17, 2015 Posted March 17, 2015 just got MBS running on my hopper but im not sure if im seeing the correct behavior. I have three views movies, tv, anime. However when i bring up MB in the hopper it only shows me directories for movies and tv. I do see that my anime has been lumped in with my regular tv shows under the tv directory. Is this the correct behavior? My expectation is that i would see a different directory that matches each defined view within the webgui.
SHSPVR 125 Posted March 18, 2015 Posted March 18, 2015 just got MBS running on my hopper but im not sure if im seeing the correct behavior. I have three views movies, tv, anime. However when i bring up MB in the hopper it only shows me directories for movies and tv. I do see that my anime has been lumped in with my regular tv shows under the tv directory. Is this the correct behavior? My expectation is that i would see a different directory that matches each defined view within the webgui. That the case with the hopper
