FightingIrish 4 Posted December 28, 2021 Posted December 28, 2021 Where is the channel mapping file located for synology dsm7 running emby 4.6.7? I'm asking because I moved emby to my new nas and the configuration restore did not bring the mappings over. I was using dsm6 prior just in case that makes a difference. I'm hoping to copy the mapping file over so I don't have to re-map all the channels again. TIA
Carlo 4561 Posted December 28, 2021 Posted December 28, 2021 Hi, short of doing the official migration process from DSM 6 to DSM 7 for Emby and documented below I'm not sure you can do this. I don't recall any threads on this type of thing either. Did you try restoring the system info from the Emby Config Backup Plugin?
FightingIrish 4 Posted December 29, 2021 Author Posted December 29, 2021 it's ok as my epg was able to match most of the channels so i only had a few to do. and yes i did do a restore but the channel mappings to come through. since i get my 2nd synology nas, i wanted to start with a clean install on my existing nas otherwise i would have followed the migration instructions. all good now so we can mark this one as complete. i may have another question but i'll start a new post. thanks! 2
