AndreZ 0 Posted December 28, 2021 Posted December 28, 2021 Hello, I tried twice to install emby-server-qnap_4.6.7.0_x86_64.qpkg on a QNAP TS-251D with Firmware 4.5.4.1892. The installation progress stopped both times at 45%. The only thing I can do, is to abort the installation. Any hints? Greetings André
Luke 42240 Posted December 28, 2021 Posted December 28, 2021 Hi, can you try rebooting the NAS and then try again? Is QTS fully up to date?
AndreZ 0 Posted December 28, 2021 Author Posted December 28, 2021 Hi @Luke, thank you for this tip. For some reason this did not change anything. How long should the installation take? I am installing over the QNAP web UI - App Center - Install Manually. Is this the correct way?
AndreZ 0 Posted December 28, 2021 Author Posted December 28, 2021 ... canceled installation after 100 minutes. Still at 45%.
AndreZ 0 Posted December 29, 2021 Author Posted December 29, 2021 Why should it work now? Nothing changed since yesterday but the time.
Luke 42240 Posted December 30, 2021 Posted December 30, 2021 Sometimes this kind of thing ends up working if you give it another try.
AndreZ 0 Posted December 30, 2021 Author Posted December 30, 2021 I tried often enough this way. I will try using the command line - as soon as I understand, how to use the -A option of qpkg_cli. It tells me, it would need a parameter, but -help does not list any for this option.
AndreZ 0 Posted January 1, 2022 Author Posted January 1, 2022 Still looking for a way, to see what‘s going wrong. Can‘t get qpkg_cli to skip the cert-test.
Solution AndreZ 0 Posted January 7, 2022 Author Solution Posted January 7, 2022 After changing some settings on my NAS that caused other problems and after installing the Multimedia Console, I gave it another try and the installation finished. Don't know, which of these changes helped.
