jaycapz 3 Posted December 28, 2021 Posted December 28, 2021 Hi, I am trying to perform a password reset, I forgot my login. I followed the forgot password option and it tells me it created a file at "/home/emby/passwordreset.txt". I am unable to locate that file location on my server, I saw someone else had this issue but it was never resolved here. Any recommendations?
Dariusz 25 Posted December 28, 2021 Posted December 28, 2021 (edited) 54 minutes ago, jaycapz said: Hi, I am trying to perform a password reset, I forgot my login. I followed the forgot password option and it tells me it created a file at "/home/emby/passwordreset.txt". I am unable to locate that file location on my server, I saw someone else had this issue but it was never resolved here. Any recommendations? I just tested it out and seems to work fine. so you have a few options.. you can use Putty to ssh into the server, from there if you are comfortable with the commands you can navigate to /volume1/home/emby and the file is there. Or to make it easier on yourself, download filezilla, ssh into your server and navigate to /volume1/home/emby and download the file and open it. Hope this helps. Edited December 28, 2021 by Dariusz
Kylerh64 0 Posted December 31, 2021 Posted December 31, 2021 thx have same problem to much hasel for me Ill just move on to something else
Luke 42237 Posted December 31, 2021 Posted December 31, 2021 13 hours ago, Kylerh64 said: thx have same problem to much hasel for me Ill just move on to something else @Kylerh64, can you try what @Dariusz suggested? We're happy to help. Thanks !
