richardvrusso 13 Posted December 27, 2021 Posted December 27, 2021 Hey everyone, Is there a best practices kb for Kodi with expert settings when using emby nextgen plugin? At a minimum when I do a new install I enable the show box sets. However I was wondering if there are other settings that could be tweaked or turned off? Things like "download actor pictures" or "extract chapter thumbnails". I was thinking stuff like this is not needed for Kodi to do since it's being fed everything from the emby server? Regards, ®ich
quickmic 1709 Posted January 4, 2022 Posted January 4, 2022 Well there is not really anything to be tweaked. Only thing you can try is artwork caching, but this will not add features. It just makes Kodi a bit more snappy. Recommended for accessing Emby-server via Internet. Artwork, Chapters etc are all automatically synced in beta versions (6.x) which I recommend. It's close to be declared as stable.
richardvrusso 13 Posted January 4, 2022 Author Posted January 4, 2022 Ok sweet! Thinking I'll do a clean install of Kodi and try the beta. Thanks, Rich
