davedick 19 Posted December 27, 2021 Posted December 27, 2021 I've setup Emby to use SSL via NO IP. The emby android app via existing settings connects and I can manually type in the url and new port and it connects. I was wondering if I was to allow someone to connect thru Emby connect, would that connection be using SSL or do they have to manually add the url and port? Thanks
sross44 434 Posted December 27, 2021 Posted December 27, 2021 15 minutes ago, davedick said: I've setup Emby to use SSL via NO IP. The emby android app via existing settings connects and I can manually type in the url and new port and it connects. I was wondering if I was to allow someone to connect thru Emby connect, would that connection be using SSL or do they have to manually add the url and port? Thanks I'm 99.9% sure that Emby Connect will utilize the HTTPS port you've got set up. Someone way smarter than me can confirm, but I believe that's how it works.
Luke 42197 Posted December 27, 2021 Posted December 27, 2021 12 hours ago, sross44 said: I'm 99.9% sure that Emby Connect will utilize the HTTPS port you've got set up. Someone way smarter than me can confirm, but I believe that's how it works. It uses the remote address that is displayed on the front page of the emby server dashboard, which will be https depending on server settings. 1
