PeterEr 2 Posted December 26, 2021 Posted December 26, 2021 I have a weird problem. Some days I can watch movies for 6-8 hours without a problem. Other days, Emby on Samsung (Tizen) freezes playback after 10 minutes - and to fix it, I have to 'wake up the pc' by pressing a key on the keyboard/moving the mouse every time 10 or so minutes has passed! - love the exercise but after 8-10 runs I get tired Notes: The PC is not at sleep, not hibernating, screen saver is turned off etc. For some reason, Emby goes to sleep and 'wakes up' if the mouse moves / keyboard pressed. Google yields no solutions. Using Emby 4.6.7.0 Emby for Samsung 1.1.06 on a Samsung Smart TV (UA49RU7100KXXA). Connection between TV and PC is a Wifi router - Netgear AC1750. Strong signal. Running Emby as a service via via NSSM - the Non-Sucking Service Manager (nssm 2.24-101-g897c7ad (2017-04-26)). Thinking it could be related to certain file formats or the NSSM service perhaps, but then again that does not explain why it does happen all the time. Last movie played has these characteristics and then it Emby froze. Nothing out of the ordinary (many other movies do the same)... Any help / troubleshooting appreciated. Title1080p H264 CodecH264 AVCYes ProfileHigh Level40 Resolution1920x1080 Aspect Ratio16:9 InterlacedNo Framerate23.976 Bitrate5,100 kbps Color Primariesbt709 Color Spacebt709 Color Transferbt709 Bit Depth8 bit Pixel Formatyuv420p Reference Frames1 hardware_detection-63776144843.txt embyserver.txt
Abobader 3485 Posted December 26, 2021 Posted December 26, 2021 Hello PeterEr, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42197 Posted December 28, 2021 Posted December 28, 2021 Hi, that's strange. What if you try running the server normally as an application rather than a windows service?
PeterEr 2 Posted January 8, 2022 Author Posted January 8, 2022 Apologies for the late reply. The problem seem to be related to the scheduling of drive optimization via windows 10 "Optimize Drives". Once the scheduler is turned off, the movies does not seem to pause. I will do some more investigation and provide feedback when available.
