eltiobarbas 0 Posted December 26, 2021 Posted December 26, 2021 (edited) Hi, i have an issue with live TV. Im running stable versions and i add my Emigma2 receiver via HD Homerun, all seems perfect, i get EPG perfect and list of channels all seems ok.. Sometimes(Mostly of the time), i cant play channels, via android or via Samsung Tizen app.. Seems stuck and have black screens and sometimes close stream atuomatically, sometimes works after wait 1 or 2+- minutes, and others not load. I see sometimes create transcoding logs and others not. Can you check it? Regards embyserver.txt ffmpeg-transcode-be5fbda9-cd7c-4999-8b09-702fff5dc9b9_1.txt ffmpeg-transcode-8769ca60-f8c8-465c-bef0-8e77d98e5c7e_1.txt ffmpeg-transcode-62aa06fa-490e-4aa7-8e44-e3cf8e30564f_1.txt ffmpeg-transcode-1dca15ff-cbc4-4af1-9a1b-fa68750ef4d6_1.txt ffmpeg-transcode-079c57d9-8bfe-4529-8b4e-02f4c94ad337_1.txt ffmpeg-transcode-01b7d738-c0ff-45b2-a974-6677be06413a_1.txt Edited December 26, 2021 by eltiobarbas Added Files
Carlo 4561 Posted December 26, 2021 Posted December 26, 2021 Hi, ffmpeg is logging all kinds of errors when processing these streams complaining about missing information on the streams. What kind of streams are you exporting from Emigma2?
eltiobarbas 0 Posted December 28, 2021 Author Posted December 28, 2021 (edited) Hi, this is my actual settings. -VU+ Solo SE (Latest Openpli image 8.1) -Double Turner Enable and Working Fine -Emby Latest Beta and VU+ Plugin enable in Docker container I setup VuPlus plugin in Emby and Channels and EPG are received OK in Emby server. When i try to stream channels takes forever and mostly of the times not open. I attach logs and screenshot of the Stream a im trying to open in Samsung Tizen App. I tested stream in android with Dream Player App and streams are perfect and Opening and Zapping its really fast. But if i try with Emby Android app , same issue, really slow opening streams or no open. Regards ffmpeg-transcode-05f2c565-803e-4081-b215-ec2e73cfa517_1.txt ffmpeg-transcode-c36bbd90-9124-406c-a97d-7cb882099ec9_1.txt embyserver.txt Edited December 28, 2021 by eltiobarbas
eltiobarbas 0 Posted December 30, 2021 Author Posted December 30, 2021 I tested with enigma2 6.4 openatv image and had same issue. When transcoding takes forever, and sometimes not working.
Carlo 4561 Posted December 31, 2021 Posted December 31, 2021 Hi, looking at the ffmpeg log files ffmpeg is having a tough time with these streams as the don't seem to be in spec. I'm not sure what can be done by Emby. I'm not familiar with VU+ so I don't know, but does it do any processing of the streams? If so you may want to try other settings.
eltiobarbas 0 Posted January 10, 2022 Author Posted January 10, 2022 Hi...i still continues with this issues, only happens when trasncoding its needed it, if its direct mostly of the times open ok, but if need transcodings takes forever or sometimes directly not open stream. But if i use direct stream via VU+ , without using Emby all perfect, i tested with Android with Dream Player and PC via VLC and open and zapping perfect.
eltiobarbas 0 Posted January 12, 2022 Author Posted January 12, 2022 Any fix or clue what can be happening?
Carlo 4561 Posted January 17, 2022 Posted January 17, 2022 How do the ffmpeg logs look in Emby? Do they still show all the errors as the previous logs you uploaded show? Emby isn't going to be able to use the streams as is if nothing has changed from before.
eltiobarbas 0 Posted January 31, 2022 Author Posted January 31, 2022 Hi, I continue with the issue, the ffmpeg logs are the same like i uploaded in first post... I tested with others programs in android and pc and works perfect the streams, the issue it's with emby and transcoding.
Luke 42243 Posted February 17, 2022 Posted February 17, 2022 Hi, if you'd like to try the 4.7 beta server I'd be curious to know how that compares. Thanks.
Carlo 4561 Posted March 3, 2022 Posted March 3, 2022 @eltiobarbas Hi, Have you tried the 4.7 beta yet? We would love to get your feedback on it.
eltiobarbas 0 Posted March 4, 2022 Author Posted March 4, 2022 Hi, Im making test with Luke and new beta, in Web, iOS and Android clients works fine now, but Tizen app not want to work fine... Seems if i try to stream via AutoDirect , channels stuck with spinner and need to close and open Tizen app. But if i set Fixed Stream like for example 1080p -10Mbps all the channels with higger bitrate will open perfect because the stream will trascode, but if go to any stream with lower bitrate for example 720p streams, this stream not work becuase try to Autodirect reproduction because my settings are set to 1080p.. and then black screen and stuck app, and need to close... Sorry if not explain well... This issue its only in tizen App, the rest work fine. Regards
