Former47 1 Posted December 24, 2021 Posted December 24, 2021 Well another foolish question....I have my TV show file structure setup according to Emby spec, TV Shows\TV Show Name (year)|Season\show name sxxexx episode name.mp4. When I add the folder to the library choosing the Shows name I always get the same results. Angry Birds Toons I must be doing something wrong
Luke 42197 Posted December 24, 2021 Posted December 24, 2021 Hi, how did you setup the library in Emby library setup? What folder did you add? Can you show us an actual example? Thanks.
pwhodges 2025 Posted December 24, 2021 Posted December 24, 2021 Is your library pointing at the "TV Shows" directory, or do you add each show's folder to the library separately? If the second, it won't work right. Paul
Former47 1 Posted December 24, 2021 Author Posted December 24, 2021 So what your saying is I have to add the whole diectory "TV Shows" to the library when i choose "Folder"?
Luke 42197 Posted December 24, 2021 Posted December 24, 2021 30 minutes ago, Former47 said: So what your saying is I have to add the whole diectory "TV Shows" to the library when i choose "Folder"? Yes, although we plan to improve support for what you're trying to do in future updates. Thanks.
Former47 1 Posted December 24, 2021 Author Posted December 24, 2021 Thanks for your resonse!! I just could never find anywhere where it explained which folder to choose when adding to a Library.... Movie or TV Show Parent or Child directory
Luke 42197 Posted December 24, 2021 Posted December 24, 2021 Hi, we do have some examples in our TV and movie naming guides: https://support.emby.media/support/solutions/articles/44001159110-tv-naming
