milostv60 7 Posted December 24, 2021 Posted December 24, 2021 (edited) When using Emby for audiobooks, playback speed resets to 1x every time you reload the app, both web and android app have this issue. Even worse, accessing playback speed button requires 2 clicks more then ideally needed, making Emby a chore to use with audiobooks. Edited December 24, 2021 by milostv60 3 4
Luke 42243 Posted December 24, 2021 Posted December 24, 2021 Hi, yes we may offer remembering playback speed in future updates. We can look at making the button available without the menu, the problem is that our OSD already contains so many buttons that we'll have to look at what to take out in exchange. Thanks for the feedback.
negativzeroe 80 Posted January 16, 2022 Posted January 16, 2022 On 12/24/2021 at 9:09 AM, Luke said: Hi, yes we may offer remembering playback speed in future updates. We can look at making the button available without the menu, the problem is that our OSD already contains so many buttons that we'll have to look at what to take out in exchange. Thanks for the feedback. IMO the simple act of remembering the speed will make the button thing less important. Like if it can be set at the beginning of the book and just stay 2x until the end (including tracks) then we won't need to regularly access it.
kid941005 0 Posted August 2, 2022 Posted August 2, 2022 Why can the playback speed be adjusted, but not maintained?
Luke 42243 Posted August 2, 2022 Posted August 2, 2022 Just now, kid941005 said: Why can the playback speed be adjusted, but not maintained? Hi, it's certainly possible for future updates. Thanks.
thatgingerdude 0 Posted September 25, 2022 Posted September 25, 2022 Has there been any progress with this?
Luke 42243 Posted September 25, 2022 Posted September 25, 2022 1 hour ago, thatgingerdude said: Has there been any progress with this? Hi, not yet, sorry.
corvolio 2 Posted December 6, 2022 Posted December 6, 2022 On 12/24/2021 at 7:09 AM, Luke said: Hi, yes we may offer remembering playback speed in future updates. We can look at making the button available without the menu, the problem is that our OSD already contains so many buttons that we'll have to look at what to take out in exchange. Thanks for the feedback. any idea when this will be prioritized?
Luke 42243 Posted December 6, 2022 Posted December 6, 2022 16 minutes ago, corvolio said: any idea when this will be prioritized? I don't have an update at this time.
dinhtienvu 1 Posted December 11, 2022 Posted December 11, 2022 I really need this future, please consider, I had bought premier 1
TC100 2 Posted December 15, 2022 Posted December 15, 2022 It would be amazing to have a theatre keyboard shortcut for playback speed adjustment! 1
TerminatorAK 18 Posted November 20, 2023 Posted November 20, 2023 Yes, that's a good idea, otherwise we would have to choose again every time
Luke 42243 Posted April 23, 2024 Posted April 23, 2024 7 hours ago, Snowy99 said: Hi Luke, any update on this topic? Hi, it's certainly possible for future updates. Thanks.
Snowy99 2 Posted May 3, 2024 Posted May 3, 2024 Are any information about timeline available or a roadmap for this feature? 1
DarkStar1977 120 Posted June 10, 2024 Posted June 10, 2024 One more for this feature, in my case per tvshow, remembering playback speed when jumping to the following episode. BTW, just as an idea, what about instead of a button and option at library level "Remember playback speed" ? This will enable to just apply to specific libraries, solving the audiobooks issue, my issue and probably this issue: Hope this helps. 1
thodi 1 Posted July 27, 2024 Posted July 27, 2024 it is really annoying, on chromecast the speed settings gets reset when fast forwarding or when changing subtitles. 1
AlexSol 1 Posted September 29, 2024 Posted September 29, 2024 It looks like a very low priority thing from devs point of view, taking into account 3 years old topic. For sure there are reasons for it e.g. hard to implement on all platforms something with good UI/UX But maybe anyone here knows whether it is possible to implement something around it with user scripts? at least on web versions? Even to maintain playback speed for an active session would be really nice.
DarkStar1977 120 Posted September 29, 2024 Posted September 29, 2024 Indeed is very frustrating. Specially because this is implemented for audio, screen size, and subtitles. It's been a long since I coded but does not seems so difficult to apply if it's already applied to the others ....
happytonakai 9 Posted February 24, 2025 Posted February 24, 2025 Any updates? Really need this stuff...
Luke 42243 Posted February 24, 2025 Posted February 24, 2025 2 hours ago, happytonakai said: Any updates? Really need this stuff... Hi, what exactly do you need?
happytonakai 9 Posted February 24, 2025 Posted February 24, 2025 3 hours ago, Luke said: Hi, what exactly do you need? Hi, Luke. I mean remembering the playback speed. It is best to keep that speed across the TV series. I tried to implement it with webhooks, but it seems that emby webhooks don't support playback speed in the contents it sends. 1 1
customized 1 Posted February 28, 2025 Posted February 28, 2025 It would be spectacular to have keyboard shortcuts, or some type of scriptable parameter to adjust playback speed. Plex has "inputmaps" that can control the internal media player (mpv). For example, a keystroke (or remote button) can be trained to give the following command: "mpv: set speed 2" So that doubles the playback speed. I'm still living in a Windows Media Center world because I can't find software with full feature parity.
Luke 42243 Posted March 1, 2025 Posted March 1, 2025 On 2/24/2025 at 2:21 AM, happytonakai said: Hi, Luke. I mean remembering the playback speed. It is best to keep that speed across the TV series. I tried to implement it with webhooks, but it seems that emby webhooks don't support playback speed in the contents it sends. Hi, just to clarify, webhooks data does contain playback speed info. It is called PlaybackRate.
happytonakai 9 Posted March 1, 2025 Posted March 1, 2025 1 hour ago, Luke said: Hi, just to clarify, webhooks data does contain playback speed info. It is called PlaybackRate. OK, thank you. So it is possible to both get and set playback speed via webhooks?
