Friends 2 Posted December 22, 2021 Posted December 22, 2021 I don't mean to be to complain but the "My Media" Banner Icons are small. Is this normal? Compared to everything else on the screen they seam meh.... Is there a way to make them larger? Thanks
GrimReaper 4860 Posted December 22, 2021 Posted December 22, 2021 You can use custom CSS. Try with: On 3/8/2020 at 11:35 PM, PenkethBoy said: /* Increase My Media Image Size */ div.card.smallBackdropCard {width: 20.0%; !important;} Adjust that "20" to higher or lower value, as inclined.
Friends 2 Posted December 22, 2021 Author Posted December 22, 2021 I would love to but how? Which file would I need to change and would that change propagate to apps? I will search the forum to customize.... Thanks
Friends 2 Posted December 22, 2021 Author Posted December 22, 2021 (edited) I found this: Clicked my account profile in Emby then Display > Display Mode> TV The Banner is now larger! Thanks for pushing me forward. Edited December 22, 2021 by Friends
Luke 42197 Posted December 22, 2021 Posted December 22, 2021 Keep in mind that TV display mode is intended for usage on a large screen with remote control as your primary input. I wouldn't use that just to get bigger graphics.
Friends 2 Posted December 23, 2021 Author Posted December 23, 2021 Can you point me in the right direction to customize the css?
GrimReaper 4860 Posted December 23, 2021 Posted December 23, 2021 7 minutes ago, Friends said: Can you point me in the right direction to customize the css?
arrbee99 1836 Posted December 23, 2021 Posted December 23, 2021 You should have a browse around the css subforum, there's some nice stuff available. Unfortunately you can't apply it to apps though, only in a browser.
