jachin99 88 Posted May 10, 2022 Posted May 10, 2022 (edited) So It looks like I was able to get my bat file working outside of emby by just passing an exact file path. My issue is that emby doesn't appear to run comskip after each recording. My first thought was that it might be because I'm on beta but I can't see how that would effect anything because the bat should run independently of emby, as long as emby is telling it to kick off, right? And right now I have my command argument filled out as literrally, " {Path}" I should but my file or folder name there instead? Edited May 10, 2022 by jachin99
BillOatman 597 Posted May 10, 2022 Author Posted May 10, 2022 (edited) 6 minutes ago, jachin99 said: So It looks like I was able to get my bat file working outside of emby by just passing an exact file path. My issue is that emby doesn't appear to run comskip after each recording. My first thought was that it might be because I'm on beta but I can't see how that would effect anything because the bat should run independently of emby, as long as emby is telling it to kick off, right? Yes what you are thinking is correct, it should run the post-process (the bat file) step. I avoid betas in general and Emby ones like the plague. But in your testing, are you recording more than 1 show at a time? I never tried, but I'm not sure how well comskip would react to being run twice concurrently. Edited May 10, 2022 by BillOatman
jachin99 88 Posted May 10, 2022 Posted May 10, 2022 That probably does happen but there are other times when its only recording one show. I haven't gotten a single EDL file generated, and I have had this plugin almost since it came out. @Luke How can I confirm post processing is happenening the way it is supposed to in my server logs
Luke 42250 Posted May 10, 2022 Posted May 10, 2022 36 minutes ago, jachin99 said: That probably does happen but there are other times when its only recording one show. I haven't gotten a single EDL file generated, and I have had this plugin almost since it came out. @Luke How can I confirm post processing is happenening the way it is supposed to in my server logs The full command line gets printed to the server log.
vdrover 62 Posted May 10, 2022 Posted May 10, 2022 2 hours ago, BillOatman said: Yes what you are thinking is correct, it should run the post-process (the bat file) step. I avoid betas in general and Emby ones like the plague. But in your testing, are you recording more than 1 show at a time? I never tried, but I'm not sure how well comskip would react to being run twice concurrently. I routinely run it simultaneously. Have tested up to 3 separate instances without issue. 1
jachin99 88 Posted May 10, 2022 Posted May 10, 2022 Ok, so I'll try to update the paths. Thanks for all of the help 1
BillOatman 597 Posted May 10, 2022 Author Posted May 10, 2022 3 hours ago, vdrover said: I routinely run it simultaneously. Have tested up to 3 separate instances without issue. I love people here. 1
jachin99 88 Posted May 11, 2022 Posted May 11, 2022 I tried to insert the path but I'm still not getting an edl file when the task kicks off from emby after the recording . Here is a log snippet showing how emby runs the command 2022-05-10 20:03:00.580 Info LiveTV: Running recording post processor C:\Users\Family\AppData\Roaming\Emby-Server\Comskip\ComskipBat.bat "{E:\TV Shows 2}"
vdrover 62 Posted May 11, 2022 Posted May 11, 2022 That’s normal. If you wait a bit, the file will get updated with commercials.
jachin99 88 Posted May 11, 2022 Posted May 11, 2022 10 hours ago, vdrover said: That’s normal. If you wait a bit, the file will get updated with commercials. I gave it all night, and still didn't get an edl. If you dont mind, can you share your bat file, and emby command arguments. I'm thinking the file location isn't being passed to emby because I see the command running in my log, and I can get my bat file to process a media file when I tell it the exact location for said file.
BillOatman 597 Posted May 11, 2022 Author Posted May 11, 2022 (edited) 13 hours ago, jachin99 said: I tried to insert the path but I'm still not getting an edl file when the task kicks off from emby after the recording . Here is a log snippet showing how emby runs the command 2022-05-10 20:03:00.580 Info LiveTV: Running recording post processor C:\Users\Family\AppData\Roaming\Emby-Server\Comskip\ComskipBat.bat "{E:\TV Shows 2}" I see a couple things to look at. The file name is ComskipBat.bat? Create a c:\comskip directory, put the bat and comskip related files there, change the post processing in Emby accordingly and try. It might be having a problem going to that directory. {E:\TV Shows 2} - I believe it is supposed to get a path to a recording file, not just a directory. Have debug logging turned on when a recording finishes, it might show something. Edited May 11, 2022 by BillOatman
TMCsw 260 Posted May 12, 2022 Posted May 12, 2022 21 hours ago, jachin99 said: I tried to insert the path but I'm still not getting an edl file when the task kicks off from emby after the recording . Here is a log snippet showing how emby runs the command 2022-05-10 20:03:00.580 Info LiveTV: Running recording post processor C:\Users\Family\AppData\Roaming\Emby-Server\Comskip\ComskipBat.bat "{E:\TV Shows 2}" That last line shows that emby is not sending your batch file a proper filename ( "{E:\TV Shows 2}" ) should be more like "E:\TV Shows 2\Myshow\Season 10\Myshow S10E10 epname.ts" In Live TV -> Advanced -> Recording Post Processing -> Post-processing command line arguments: What does it say? it should say: "{path}" Also it's best quote your batch file "C:\Users\Family\AppData\Roaming\Emby-Server\Comskip\ComskipBat.bat" just incase you ever change it to something having a space in it. 1
vdrover 62 Posted May 12, 2022 Posted May 12, 2022 I'm in linux. You can see the batch file in earlier posts.
crusher11 1145 Posted May 12, 2022 Posted May 12, 2022 Is it possible to set this all up on a Synology Emby install?
jachin99 88 Posted May 12, 2022 Posted May 12, 2022 (edited) Alright, I'm at a loss on why this isn't working at this point but here is what I do believe... 1. I have emby post processing setup correctly because I pointed it at the correct file, and passed it the correct command argument shown in the attatchments below... 2. I can see emby passing the command arguments to windows in the log file. Here is what that looks like 2022-05-12 03:13:00.909 Info LiveTV: Running recording post processor C:\Comskip\ComskipBat.bat "G:\More Movies\Small Soldiers (1998)\Small Soldiers (1998).ts" 3. For whatever reason the command isn't running correctly, and comskip is failing. I don't get any kind of new log files from comskip in its folder. Here is my bat file. I put a pause at the end for troubleshooting purposes, and this is the exact command that runs after a recoding is completed. set drive=%~d1 set folder=%~p1 set filename=%~n1 c: cd\Comskip comskip --ini=comskip.ini "%drive%%folder%%filename%.ts" %drive% del "%folder%%filename%.log" del "%folder%%filename%.logo.txt" del "%folder%%filename%.txt" pause I ran the exact command from my log file in the command line, and here is what I get. The only thing that I see that is out of the ordinary is a wierd double space after G:\ when it tries to create the new directory at the end. It looks to me like comskip is running correctly but failing to make the new directory. Microsoft Windows [Version 10.0.19041.1415] (c) Microsoft Corporation. All rights reserved. C:\Comskip>C:\Comskip\ComskipBat.bat "G:\More Movies\Small Soldiers (1998)\Small Soldiers (1998).ts" C:\Comskip>set drive=G: C:\Comskip>set folder=\More Movies\Small Soldiers (1998)\ C:\Comskip>set filename=Small Soldiers (1998) C:\Comskip>c: C:\Comskip>cd\Comskip C:\Comskip>comskip --ini=comskip.ini "G: \More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .ts" Comskip 0.82.012, made using ffmpeg Donator build The commandline used was: comskip --ini=comskip.ini "G: \More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .ts" Setting ini file to comskip.ini as per commandline Using comskip.ini for initiation values. Mpeg: G: \More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .ts Exe comskip.exe Logo: G: \More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .logo.txt Ini: comskip.ini Detection Methods to be used: 1) Black Frame 2) Logo - Give up after 2000 seconds 3) Resolution Change 4) Aspect Ratio ComSkip throttles back from -0001 to -0001. The time is now 0842 so it's full speed ahead! Settings -------- [Main Settings] ;the sum of the values for which kind of frames comskip will consider as possible cutpoints: 1=uniform (black or any other color) frame, 2=logo, 4=scene change, 8=resolution change, 16=closed captions, 32=aspect ration, 64=silence, 255=all. detect_method=43 ;Set to 10 to show a lot of extra info, level 5 is also OK, set to 0 to disable verbose=10 ;Frame not black if any of the pixels of the frame has a brightness greater than this (scale 0 to 255) max_brightness=60 maxbright=1 ;Frame not pure black if a small number of the pixels of the frame has a brightness greater than this. To decide if the frame is truly black, comskip will also check average brightness (scale 0 to 255) test_brightness=40 ; max_avg_brightness=25 ; max_commercialbreak=600 ; min_commercialbreak=25 ; max_commercial_size=125 ; min_commercial_size=4 ; min_show_segment_length=250 ; max_volume=500 ; max_silence=100 ; non_uniformity=500 [Detailed Settings] min_silence=12 remove_silent_segments=0 noise_level=5 brightness_jump=200 fps=1 validate_silence=1 validate_uniform=1 validate_scenechange=1 global_threshold=1.05 disable_heuristics=4 cut_on_ac_change=1 [CPU Load Reduction] thread_count=2 hardware_decode=0 play_nice_start=-1 play_nice_end=-1 play_nice_sleep=2 [Input Correction] max_repair_size=200 ms_audio_delay=5 volume_slip=40 lowres=0 skip_b_frames=0 [Aspect Ratio] ar_delta=0.08 cut_on_ar_change=1 [Global Removes] padding=0 remove_before=0 remove_after=0 added_recording=14 delete_show_after_last_commercial=0 delete_show_before_first_commercial=0 delete_show_before_or_after_current=0 delete_block_after_commercial=0 min_commercial_break_at_start_or_end=39 always_keep_first_seconds=0 always_keep_last_seconds=0 [USA Specific] intelligent_brightness=0 black_percentile=0.0076 uniform_percentile=0.003 score_percentile=0.71 [Main Scoring] length_strict_modifier=3 length_nonstrict_modifier=1.5 combined_length_strict_modifier=2 combined_length_nonstrict_modifier=1.25 ar_wrong_modifier=2 ac_wrong_modifier=1 excessive_length_modifier=0.01 dark_block_modifier=0.3 min_schange_modifier=0.5 max_schange_modifier=2 logo_present_modifier=0.01 punish_no_logo=1 [Detailed Scoring] punish=0 reward=0 punish_threshold=1.3 punish_modifier=2 reward_modifier=0.5 [Logo Finding] border=10 give_up_logo_search=2000 delay_logo_search=0 logo_max_percentage_of_screen=0.12 ticker_tape=0 ticker_tape_percentage=0 top_ticker_tape=0 top_ticker_tape_percentage=0 ignore_side=0 ignore_left_side=0 ignore_right_side=0 subtitles=0 logo_at_bottom=0 logo_threshold=0.75 logo_percentage_threshold=0.25 logo_filter=0 aggressive_logo_rejection=0 edge_level_threshold=5 edge_radius=2 edge_weight=10 edge_step=1 num_logo_buffers=50 use_existing_logo_file=1 two_pass_logo=1 [Logo Interpretation] connect_blocks_with_logo=1 logo_percentile=0.92 logo_fraction=0.4 shrink_logo=5 shrink_logo_tail=0 before_logo=0 after_logo=0 where_logo=0 min_black_frames_for_break=1 [Closed Captioning] ccCheck=0 cc_commercial_type_modifier=4 cc_wrong_type_modifier=2 cc_correct_type_modifier=0.75 [Live TV] live_tv=0 live_tv_retries=4 require_div5=0 div5_tolerance=-1 incommercial_frames=1000 [Output Control] output_default=1 output_chapters=0 output_plist_cutlist=0 output_zoomplayer_cutlist=0 output_zoomplayer_chapter=0 output_scf=0 output_vcf=0 output_vdr=0 output_projectx=0 output_avisynth=0 output_videoredo=0 output_videoredo3=0 videoredo_offset=2 output_btv=0 output_edl=1 output_live=0 edl_offset=0 timeline_repair=1 edl_skip_field=0 output_edlp=0 output_bsplayer=0 output_edlx=0 output_cuttermaran=0 output_mpeg2schnitt=0 output_womble=0 output_mls=0 output_mpgtx=0 output_dvrmstb=0 output_dvrcut=0 output_ipodchap=0 output_framearray=0 output_debugwindow=0 output_tuning=0 output_training=0 output_false=0 output_aspect=0 output_demux=0 output_data=0 output_srt=0 output_smi=0 output_timing=0 output_incommercial=0 output_ffmeta=0 output_ffsplit=0 delete_logo_file=0 output_mkvtoolnix=0 cutscene_frame=0 cutscene_threshold=10 windowtitle="Comskip - %s" cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\"" mpeg2schnitt_options="mpeg2schnitt.exe /S /E /R25 /Z %2 %1" avisynth_options="LoadPlugin(\"MPEG2Dec3.dll\") \nMPEG2Source(\"%s\")\n" dvrcut_options="dvrcut \"%s.dvr-ms\" \"%s_clean.dvr-ms\" " [Sage Workarounds] sage_framenumber_bug=0 sage_minute_bug=0 enable_mencoder_pts=0 No such file or directory - could not create file G: \More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .txt C:\Comskip>G: G:\>del "\More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .log" Could Not Find G:\More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .log G:\>del "\More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .logo.txt" Could Not Find G:\More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .logo.txt G:\>del "\More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .txt" Could Not Find G:\More Movies\Small Soldiers (1998)\ Small Soldiers (1998) .txt G:\>pause Press any key to continue . . . G:\> Edited May 12, 2022 by jachin99
richt 95 Posted May 12, 2022 Posted May 12, 2022 The leading space for the filename is something Windows doesn't handle well and could be the problem. See this article. From your batch file, I'm not quite sure where the spaces are coming from, however you may be able to simplify this and avoid the issue completely. Unless you are calling multiple post processing operations, there is no need to use a batch file for comskip. See the screen cap below. This works quite well. The main requirement is that your comskip.ini file must reside in the same folder as comskip.exe In order to remove the .txt and .logo files from the folders add / update the following lines in your comskip.ini output_default=0 ; This suppresses the production of .txt files. delete_logo_file=1 ; This deletes the .logo file when comskip is completed.
Spaceboy 2573 Posted May 12, 2022 Posted May 12, 2022 15 hours ago, crusher11 said: Is it possible to set this all up on a Synology Emby install? no
TMCsw 260 Posted May 12, 2022 Posted May 12, 2022 @jachin99 Although @richt gave you a simpler(better) solution I can see by highlighting the 3 set lines in your posted batch file that they all have a trailing space in them. That is why it fails.
jachin99 88 Posted May 13, 2022 Posted May 13, 2022 10 hours ago, richt said: The leading space for the filename is something Windows doesn't handle well and could be the problem. See this article. From your batch file, I'm not quite sure where the spaces are coming from, however you may be able to simplify this and avoid the issue completely. Unless you are calling multiple post processing operations, there is no need to use a batch file for comskip. See the screen cap below. This works quite well. The main requirement is that your comskip.ini file must reside in the same folder as comskip.exe In order to remove the .txt and .logo files from the folders add / update the following lines in your comskip.ini output_default=0 ; This suppresses the production of .txt files. delete_logo_file=1 ; This deletes the .logo file when comskip is completed. That seemed to do the trick for the time being but the whitespace issue is something I would still like to look into. Thanks everyone for all of the help
crusher11 1145 Posted May 16, 2022 Posted May 16, 2022 I've managed to set up comskip on my Synology, and run it on a recording, but it's only produced a TXT file, not an EDL file. It's also deleting the logo file, so it doesn't seem to be using the ini that's present in its folder. Not sure what's going on here?
Spaceboy 2573 Posted May 16, 2022 Posted May 16, 2022 you need to set the right options in comskip.ini. its going to be unbelievably slow on your syno though
crusher11 1145 Posted May 16, 2022 Posted May 16, 2022 3 minutes ago, Spaceboy said: you need to set the right options in comskip.ini. its going to be unbelievably slow on your syno though I frequently watch things weeks after they're recorded. The comskip ini doesn't seem to be applying to the execution though, as it's set to output an EDL and not delete the logo file.
Spaceboy 2573 Posted May 16, 2022 Posted May 16, 2022 post your comskip.ini. otherwise we're just guessing. there was a pdf around somewhere which gave some tips but i don't see it anymore
crusher11 1145 Posted May 16, 2022 Posted May 16, 2022 This should create an EDL and leave a logo file behind, from my reading, but it does neither. comskip.ini
BillOatman 597 Posted May 16, 2022 Author Posted May 16, 2022 3 hours ago, crusher11 said: This should create an EDL and leave a logo file behind, from my reading, but it does neither. comskip.ini 6.11 kB · 1 download I would suggest running with the file in the first post as it has been shown to work. If that doesn't work, the problem probably isn't the ini file.
