muppet4k 10 Posted February 6, 2024 Posted February 6, 2024 3 hours ago, vdrover said: My original post was not docker, but i now use docker. In your case, the DLL goes in the emby/plugins folder. Which Emby Package are you using in your docker? Because I have the Problem to have no bash there , and also apt-get not working I am using the official emby/embyserver package but no apt-get or bash included
vdrover 62 Posted February 6, 2024 Posted February 6, 2024 7 minutes ago, muppet4k said: Which Emby Package are you using in your docker? Because I have the Problem to have no bash there , and also apt-get not working I am using the official emby/embyserver package but no apt-get or bash included What is the 'config volume' parameters of your emby container? For example, here's mine: volumes: - home/appdata/emby:/config So my plugins folder is `home/appdata/emby/plugins`. I can just copy the file using the local terminal, or the built in file manager. I don't need to worry about apt-get nor bash inside the emby container.
muppet4k 10 Posted February 6, 2024 Posted February 6, 2024 (edited) 36 minutes ago, vdrover said: What is the 'config volume' parameters of your emby container? For example, here's mine: volumes: - home/appdata/emby:/config So my plugins folder is `home/appdata/emby/plugins`. I can just copy the file using the local terminal, or the built in file manager. I don't need to worry about apt-get nor bash inside the emby container. I think I need a bash to install these commands: $ sudo apt-get update $ sudo apt-get install ffmpeg libavcodec-dev libavformat-dev libavutil-dev autoconf automake git libargtable2-dev libtool $ git clone git://github.com/erikkaashoek/Comskip $ cd Comskip $ ./autogen.sh $ ./configure $ make $ sudo make install In my Docker setup with the official file I have no bash so I installed it right now with the community package.... https://synocommunity.com/package/comskip But I think its an old Version... But when I log in over my terminal ssh on my Mac I can use the command: Comskip and its working but not from the emby docker So how did you installed the emby Server? Or where did you installed your codes above ? Edited February 6, 2024 by muppet4k
vdrover 62 Posted February 6, 2024 Posted February 6, 2024 @muppet4k https://www.smarthomebeginner.com/docker-media-server-2022/
BillOatman 597 Posted February 6, 2024 Author Posted February 6, 2024 4 hours ago, JanLenoch said: Hey @BillOatman, I just deployed the 2.1 version and found that the plugin fails to skip commercials. I found that ServerEntryPoint.PlaybackProgress() throws NREs. I set up remote debugging on my box and revealed the NREs happen when getting a control session. First, the code determines that the session found in event args doesn't support remote control. Then, when looking for suitable sessions through SessionManager, the NREs get thrown since you don't use a null-coalescing "?" operator after FirstOrDefault(). When trying to dig deeper, I found that it probably boils down to Emby.Server.Implementations.Session.WebSocketManager.SupportsMediaControl returning false due to GetActiveSockets() failing to find anything. I have a pretty vanilla 4.8 installation. I didn't do any tweaks beyond what an admin can alter in the admin area. Do you have any ideas what might have gone wrong? CC @Luke Thanks! Thanks for letting me know about the null issue. It is my understanding that Emby clients some devices simply do not support remote control. What device are you using? And is it running the more recent Emby client?
vdrover 62 Posted February 6, 2024 Posted February 6, 2024 @BillOatmanDid you make a new release today with the same version # as yesterday?
muppet4k 10 Posted February 7, 2024 Posted February 7, 2024 30 minutes ago, vdrover said: @muppet4k https://www.smarthomebeginner.com/docker-media-server-2022/ So you have a nas with Ubuntu and there a docker or vm with emby ? or what’s your system ? How did install the comskip ? Did you install it on ubuntu and your docker where emby can access to comskip ? I think I must mount it to get access in emby ?
BillOatman 597 Posted February 7, 2024 Author Posted February 7, 2024 12 minutes ago, vdrover said: @BillOatmanDid you make a new release today with the same version # as yesterday? Yes, same binary I just added a PDF 1
vdrover 62 Posted February 7, 2024 Posted February 7, 2024 1 minute ago, BillOatman said: Yes, same binary I just added a PDF LOL!
JanLenoch 1 Posted February 7, 2024 Posted February 7, 2024 2 hours ago, BillOatman said: Thanks for letting me know about the null issue. It is my understanding that Emby clients some devices simply do not support remote control. What device are you using? And is it running the more recent Emby client? Thanks for a prompt reply! I see, so that's the purpose of the ClientCapabilities class. I wasn't using any other client than my browser (Edge). After installing a Theater client it started working. Problem solved. Thank you @BillOatman!
BillOatman 597 Posted February 7, 2024 Author Posted February 7, 2024 1 hour ago, JanLenoch said: Thanks for a prompt reply! I see, so that's the purpose of the ClientCapabilities class. I wasn't using any other client than my browser (Edge). After installing a Theater client it started working. Problem solved. Thank you @BillOatman! All Emby clients are not created equal. ClientCapabilities just tells you what each is capable of. Not sure why installing theater would impact that, but glad it's working 1
vdrover 62 Posted February 7, 2024 Posted February 7, 2024 13 hours ago, muppet4k said: How did install the comskip ? Did you install it on ubuntu and your docker where emby can access to comskip ? I actually don't use the triggers in Emby for anything. I use this wonderful image that "watches" my libraries for .TS files, then converts them to MKV and generates the EDL files. Once the EDL files are available, the comskip plugin that @BillOatmanmade works just fine.
muppet4k 10 Posted February 7, 2024 Posted February 7, 2024 17 minutes ago, vdrover said: I actually don't use the triggers in Emby for anything. I use this wonderful image that "watches" my libraries for .TS files, then converts them to MKV and generates the EDL files. Once the EDL files are available, the comskip plugin that @BillOatmanmade works just fine. I will look later through it So problem is that I am dependent from the syno community with com skip, because In my docker I can't install nothing with apt-get
muppet4k 10 Posted February 7, 2024 Posted February 7, 2024 # / # ls -la /comskip total 304 drwxr-xr-x 1 257247 207066 14 Mar 29 2023 . drwxr-xr-x 1 root root 194 Feb 7 14:33 .. -rwxr-xr-x 1 257247 207066 309176 Mar 29 2023 comskip
vdrover 62 Posted February 7, 2024 Posted February 7, 2024 (edited) 2 minutes ago, muppet4k said: So problem is that I am dependent from the syno community with com skip, because In my docker I can't install nothing with apt-get I don 't know why you need apt-get. Can't you Use the docker container manager to add https://github.com/chacawaca/docker-post-recording? It includes comskip and the other post-processing utilities. Edited February 7, 2024 by vdrover
muppet4k 10 Posted February 7, 2024 Posted February 7, 2024 18 minutes ago, vdrover said: I don 't know why you need apt-get. Can't you Use the docker container manager to add https://github.com/chacawaca/docker-post-recording? It includes comskip and the other post-processing utilities. Ok I thought you installed it seperate like you step by step guide in post page 7 I try it with the docker image
richt 95 Posted February 7, 2024 Posted February 7, 2024 2 hours ago, vdrover said: I actually don't use the triggers in Emby for anything. I use this wonderful image that "watches" my libraries for .TS files, then converts them to MKV and generates the EDL files. Once the EDL files are available, the comskip plugin that @BillOatmanmade works just fine. Thanks for this. I had been testing Emby in Docker, but hadn't yet found a good way to manage comskip. I'm checking it out. 1
vdrover 62 Posted February 7, 2024 Posted February 7, 2024 18 minutes ago, richt said: Thanks for this. I had been testing Emby in Docker, but hadn't yet found a good way to manage comskip. I'm checking it out. It’s pretty amazing.
muppet4k 10 Posted February 7, 2024 Posted February 7, 2024 1 hour ago, richt said: Thanks for this. I had been testing Emby in Docker, but hadn't yet found a good way to manage comskip. I'm checking it out. So I am not alone with that
muppet4k 10 Posted February 8, 2024 Posted February 8, 2024 21 hours ago, vdrover said: I don 't know why you need apt-get. Can't you Use the docker container manager to add https://github.com/chacawaca/docker-post-recording? It includes comskip and the other post-processing utilities. so i installed it but I have some permission problems... Which permissions need the folder? Or must I setup something in the docker settings ?
vdrover 62 Posted February 8, 2024 Posted February 8, 2024 45 minutes ago, muppet4k said: so i installed it but I have some permission problems... Which permissions need the folder? Or must I setup something in the docker settings ? I would put these questions here.
jsmith100 1 Posted February 11, 2024 Posted February 11, 2024 I successfully setup comskip and the emby_preprocessing.sh, with successful tests (Thank you for the well written instructions). The problem that i have now is that I can't get comskip to kickoff when I start a recording or once a recording has completed. I have the plugin installed, and as I said, it all works if I run it from the command line (Ubuntu config btw)... I am running Emby in docker, but I'm not sure that is the issue. I believe the issue may be with the PATH information, but again not 100% sure. I looked in the emby logs and didn't see anything to point me to a place to start troubleshooting. Another note and why I think it may be a PATH problem.. When I record a show, let's say yellowstone, the directory structure is this: X:/tvshows/yellowstone/yellowstone.ts. My preference is to just have all the tvshows record to the main tvshows directory, but Emby is automatically creating a directory for the shows. I went to the livetv xml and subdirectories is set to fals...I tested setting it to true to see what happens and all it does is create the following structure: X:/tvshows/series/yellowstone/yellowstone.ts If someone can point me into the right place, that would be awesome! Thanks in advance for your time. Post processing Application: /usr/bin/comskip Post-processor command line arguments: -ini=/etc/comskip.ini "{path}"embyserver.txt
fireplex 12 Posted February 12, 2024 Posted February 12, 2024 For those running emby as a docker under unRAID, I got comskip processing by using another docker called unmanic available from unRAID apps section. Would love to have an option for a popup asking if you want to skip the advert or not (rather than forcing it), no sure it that would be possible with the plugin?
vdrover 62 Posted February 12, 2024 Posted February 12, 2024 8 minutes ago, fireplex said: Would love to have an option for a popup asking if you want to skip the advert or not (rather than forcing it), no sure it that would be possible with the plugin? Does unmanic create EDL files? If so, it should work with this plugin.
