richt 95 Posted May 13, 2023 Posted May 13, 2023 @TMCswThanks for the suggestions. I think I'll stick with running comskip twice as its working and I'll just wait for a fix.
BoomerGamer62 18 Posted May 23, 2023 Posted May 23, 2023 Passing along a problem I found in the sample .bat file provided with comskipper. Comskipper was working 75% of the time for me, but it was annoying it wouldnt work all the time. Nothing showed up in the logs, because all the Emby log shows in the call to the .bat file. I then ran the .bat file manually on one of the files that did not create an .edl and found out that there is an issue when the path name or filename has a special character in it &()[]{}^=;!'+,`~ () <>| For example, a pathname of \Tom & Jerry (1940)\ wont work because of the ampersand and paretheses. The fix is to put quotes around your parameter setup. Change set folder=%~p1 set filename=%~n1 to set "folder=%~p1" set "filename=%~n1" @BillOatman, might want to change this in your sample .bat Thanks for a great plugin though! 2
BrianJFox 18 Posted June 5, 2023 Posted June 5, 2023 Any chance this can be added to the Emby plugin's catalog? 3
BillOatman 597 Posted September 26, 2023 Author Posted September 26, 2023 On 6/5/2023 at 5:09 PM, BrianJFox said: Any chance this can be added to the Emby plugin's catalog? Not really. It requires additional steps outside of the plugin like running comskip, plus I cannot guarantee prompt support. I made it open source. 1
mike3821 67 Posted November 6, 2023 Posted November 6, 2023 (edited) Trying to get Live TV Com Skip working. Am I missing anything? Edited November 6, 2023 by mike3821
TMCsw 260 Posted November 7, 2023 Posted November 7, 2023 On 11/6/2023 at 1:54 PM, mike3821 said: Trying to get Live TV Com Skip working. Am I missing anything? It's hard to tell what you are showing/asking but it appears you are not passing the file [path]file-name to your bash script you need to add "%recording.path%" to the scripterx parameters like this:
mike3821 67 Posted November 7, 2023 Posted November 7, 2023 46 minutes ago, TMCsw said: It's hard to tell what you are showing/asking but it appears you are not passing the file [path]file-name to your bash script you need to add "%recording.path%" to the scripterx parameters like this: I’m not sure where I got that information but that’s what I’ve been using for a couple years now when recording TV and it works. does it need to be different for this portion?
ImWrong 0 Posted November 7, 2023 Posted November 7, 2023 16 minutes ago, mike3821 said: and it works. does it need to be different for this portion? I don't understand what is problem you are having?
mike3821 67 Posted November 8, 2023 Posted November 8, 2023 59 minutes ago, ImWrong said: I don't understand what is problem you are having? When watching in progress recordings to skip commercials.
ttgapers 99 Posted November 8, 2023 Posted November 8, 2023 On 5/23/2023 at 2:45 PM, BoomerGamer62 said: The fix is to put quotes around your parameter setup. Change set folder=%~p1 set filename=%~n1 to set "folder=%~p1" set "filename=%~n1" Really good catch! 1
Deihmos 170 Posted January 14, 2024 Posted January 14, 2024 Can anyone help me with linux? I can't seem to get it to launch comskip when a recording begins. I am not sure what I am doing wrong.
vdrover 62 Posted January 14, 2024 Posted January 14, 2024 (edited) @DeihmosI wrote an details ubuntu tutorial. If you follow it from beginning to end, you should be able to sort it out on your Debian system. In my case. the `Post-processing application` was `/usr/local/bin/comskip` and the `command line arguments` were `--ini=/etc/comskip.ini "{path}"`. Follow my steps to find your application path, and other details. Edited January 14, 2024 by vdrover 1
Deihmos 170 Posted January 15, 2024 Posted January 15, 2024 @vdroverThanks. I found your post and followed the instructions after posting the question. It works, 1
Mister Steve 30 Posted January 20, 2024 Posted January 20, 2024 Thanks to all that have contributed, chiefly @BillOatman. Comskipper was simple to set up and I've had good results with Emby on Debian, Comskip 0.82.009. Sometimes Comskip will over-skip and jump to a later portion of a show. Is there a way to disable skipping during playback when the detection is not accurate?
vdrover 62 Posted January 20, 2024 Posted January 20, 2024 Only to delete the EDL manually. Have you looked into customizing the comskip.ini for each show? Might help for problematic programs.
BillOatman 597 Posted January 21, 2024 Author Posted January 21, 2024 On 1/19/2024 at 10:10 PM, Mister Steve said: Thanks to all that have contributed, chiefly @BillOatman. Comskipper was simple to set up and I've had good results with Emby on Debian, Comskip 0.82.009. Sometimes Comskip will over-skip and jump to a later portion of a show. Is there a way to disable skipping during playback when the detection is not accurate? If you rewind back to the point of the problem it should not skip the 2nd time.
Mister Steve 30 Posted January 23, 2024 Posted January 23, 2024 Thanks for the suggestions. Ideally a control would appear during playback (like CC on/off) when an EDL file is available, but this feature is likely beyond the ability of a plugin. If we hit a show that consistently does not work I'll create a custom comskip.ini but that's not been necessary so far. 1
BillOatman 597 Posted January 23, 2024 Author Posted January 23, 2024 5 hours ago, Mister Steve said: Thanks for the suggestions. Ideally a control would appear during playback (like CC on/off) when an EDL file is available, but this feature is likely beyond the ability of a plugin. If we hit a show that consistently does not work I'll create a custom comskip.ini but that's not been necessary so far. Yes, it is. 1
muzicman0 85 Posted January 27, 2024 Posted January 27, 2024 I don't understand what I am doing wrong. I have valid EDL files that work for Kodi just fine, but I can't get Comskipper to work with them. It shows up in plugins, and I have it set to auto skip commercials, and show commercial duration. But it is not skipping commercials. I have tried it in a web browser, and my Nvidia Shields. Nothing. What am I missing?
BillOatman 597 Posted January 28, 2024 Author Posted January 28, 2024 20 hours ago, muzicman0 said: I don't understand what I am doing wrong. I have valid EDL files that work for Kodi just fine, but I can't get Comskipper to work with them. It shows up in plugins, and I have it set to auto skip commercials, and show commercial duration. But it is not skipping commercials. I have tried it in a web browser, and my Nvidia Shields. Nothing. What am I missing? Shield should certainly work. Please send the edl file, and a emby server debug log right after playing through a commercial.
muzicman0 85 Posted January 29, 2024 Posted January 29, 2024 I'll get the log as soon as I can. I have a few clients connected, so I want to wait until the server is free. I will attach the actual file as well, but here are the contents of the edl: 0.00 95.35 0 525.16 588.72 0 818.78 1038.79 0 1334.88 1565.48 0 1888.44 1917.43 0 Night Court (2023) - S02E05 - Hold the Pickles, Keep the Change.edl
BillOatman 597 Posted January 29, 2024 Author Posted January 29, 2024 15 hours ago, muzicman0 said: I'll get the log as soon as I can. I have a few clients connected, so I want to wait until the server is free. I will attach the actual file as well, but here are the contents of the edl: 0.00 95.35 0 525.16 588.72 0 818.78 1038.79 0 1334.88 1565.48 0 1888.44 1917.43 0 Night Court (2023) - S02E05 - Hold the Pickles, Keep the Change.edl 82 B · 0 downloads That file looks fine. 0 at the end is correct, tab delimited columns. Unfortunately I think you are going to see that your client device does not support skipping.
muzicman0 85 Posted January 29, 2024 Posted January 29, 2024 What devices support it? I have a Chromecast with TV, 2 Shields, and a Fire TV Max. Plus any browser.
BillOatman 597 Posted January 29, 2024 Author Posted January 29, 2024 2 hours ago, muzicman0 said: What devices support it? I have a Chromecast with TV, 2 Shields, and a Fire TV Max. Plus any browser. I don't know what ones do and don't. I know it works for shields as that's what I have. Pretty sure I had it working with the browser as well but can't swear to that.
