Spaceboy 2573 Posted January 4, 2023 Posted January 4, 2023 8 hours ago, BillOatman said: Oh its the ini file. Odd because I don't think I did anything different this time than the others. The shouldn't stop the DLL from working. I'll build with the older Emby nuget and see if that works for you. I'm running whatever the latest stable Emby is, I'm not home not to take a look at the number. it is odd - not certain this will fix it but its the only thing i could think of.
roaku 842 Posted January 4, 2023 Posted January 4, 2023 2 minutes ago, Spaceboy said: it is odd - not certain this will fix it but its the only thing i could think of. I've been known to accidentally copy the dll to the system plugins directory instead of the programdata plugins directory. 1
Spaceboy 2573 Posted January 4, 2023 Posted January 4, 2023 5 minutes ago, roaku said: I've been known to accidentally copy the dll to the system plugins directory instead of the programdata plugins directory. i double and triple checked for that before posting
roaku 842 Posted January 4, 2023 Posted January 4, 2023 6 minutes ago, Spaceboy said: i double and triple checked for that before posting It looks like you're copying an ini file for the comskipper app itself to the plugins directory, not the ComSkipper plugin dll. 1
Spaceboy 2573 Posted January 4, 2023 Posted January 4, 2023 3 minutes ago, roaku said: It looks like you're copying an ini file for the comskipper app itself to the plugins directory, not the ComSkipper plugin dll. thats a new one 1
BillOatman 597 Posted January 4, 2023 Author Posted January 4, 2023 1 hour ago, Spaceboy said: thats a new one Was that it?
vdrover 62 Posted January 5, 2023 Posted January 5, 2023 @BillOatmanAny interest in opening the wiki area on Github? Would make updating install instructions a lot easier.
Spaceboy 2573 Posted January 5, 2023 Posted January 5, 2023 1 hour ago, BillOatman said: Was that it? yeah sorry, in my haste to install i took the ini from the first post
BillOatman 597 Posted January 5, 2023 Author Posted January 5, 2023 15 hours ago, Spaceboy said: yeah sorry, in my haste to install i took the ini from the first post No worries, Im just glad that all it was
BillOatman 597 Posted January 5, 2023 Author Posted January 5, 2023 16 hours ago, vdrover said: @BillOatmanAny interest in opening the wiki area on Github? Would make updating install instructions a lot easier. Opening up? How would I do that.
crusher11 1145 Posted January 16, 2023 Posted January 16, 2023 If I start playback of a recording before the comskip process finishes, so there's no EDL file yet, will it start skipping commercials once comskip finishes and the EDL is available or would I need to stop and restart playback?
BillOatman 597 Posted January 16, 2023 Author Posted January 16, 2023 1 hour ago, crusher11 said: If I start playback of a recording before the comskip process finishes, so there's no EDL file yet, will it start skipping commercials once comskip finishes and the EDL is available or would I need to stop and restart playback? Restart if there is no EDL file. It loads that data when playback starts. 1
crusher11 1145 Posted January 18, 2023 Posted January 18, 2023 Is there a way to get an alert when the EDL has been created?
BillOatman 597 Posted January 20, 2023 Author Posted January 20, 2023 (edited) On 1/18/2023 at 2:51 PM, crusher11 said: Is there a way to get an alert when the EDL has been created? Not really, comskip creates that. Maybe in the script that runs comskip something could be added Edited January 20, 2023 by BillOatman
vdrover 62 Posted January 20, 2023 Posted January 20, 2023 On 1/18/2023 at 1:51 PM, crusher11 said: Is there a way to get an alert when the EDL has been created? What kind of notification are you hoping for and on what OS?
crusher11 1145 Posted January 21, 2023 Posted January 21, 2023 15 hours ago, vdrover said: What kind of notification are you hoping for and on what OS? Well all my other Emby server notifications come via PushBullet. So that would make sense. The server is on Synology.
alexcapone 0 Posted January 22, 2023 Posted January 22, 2023 On 1/21/2023 at 6:19 AM, crusher11 said: The server is on Synology. Hello, I was digging through the this thread and noticed you were one of the only users that set comskip on synology. Could you point me to any resource you used to set this up? RIght now I have Live TV+Recording working fine. Comskip is the last piece to finish my Live TV/DVR setup.
crusher11 1145 Posted January 23, 2023 Posted January 23, 2023 https://synopackage.com/sources/synocommunity
alexcapone 0 Posted January 23, 2023 Posted January 23, 2023 (edited) 1 hour ago, crusher11 said: https://synopackage.com/sources/synocommunity So I downloaded that package (as well as ffmpeg package) and read the wiki but it doesn't tell me how to configure it in Emby. Based on reading your previous post you just set it up in your post process record settings and it works? Would you mind sharing a screenshot of your final configuration? It would help me as a reference to set mine up accordingly. Edit: Is this still your configuration?: My install is also on volume1 so it wouldn't change in my setup either. I'm just waiting for a recording to finish and see if the process runs. Edit 2: Looks like the wiki shows the default path to be /volume1/@appstore/comskip/bin/compskip.ini (which is slightly different than your path). I verified via ssh that my ini file was located in the default path. I saw that you posted your ini file. Did you make changes to the default ini file? Not sure about all of these settings to change. Edited January 23, 2023 by alexcapone
crusher11 1145 Posted January 23, 2023 Posted January 23, 2023 I don't believe I changed anything, but it's been a while.
jriker1 21 Posted February 14, 2023 Posted February 14, 2023 (edited) Thread to long to find this. I saw some threads with people for the last few years complaining about Emby not having EDL support. Just started recording with Emby and used this plugin with it. So see the recording and the edl file. Will this automatically skip commercials with the Shield Pro? It's in use right now so can't verify. Little I've found looked like it popped up the skip message but didn't actually skip anything. Edited February 14, 2023 by jriker1
samuelqwe 317 Posted February 14, 2023 Posted February 14, 2023 39 minutes ago, jriker1 said: Thread to long to find this. I saw some threads with people for the last few years complaining about Emby not having EDL support. Just started recording with Emby and used this plugin with it. So see the recording and the edl file. Will this automatically skip commercials with the Shield Pro? It's in use right now so can't verify. Little I've found looked like it popped up the skip message but didn't actually skip anything. Yes, it should be skipping automatically. If that's not happening, there could be something blocking the plugin from sending playback commands to the Shield.
AKSkinz 10 Posted February 14, 2023 Posted February 14, 2023 2 hours ago, jriker1 said: Thread to long to find this. I saw some threads with people for the last few years complaining about Emby not having EDL support. Just started recording with Emby and used this plugin with it. So see the recording and the edl file. Will this automatically skip commercials with the Shield Pro? It's in use right now so can't verify. Little I've found looked like it popped up the skip message but didn't actually skip anything. I use it on my Shield and it works fine. Make sure you have the plugin enabled after you install it. Also check the edl file content to make sure that comskip is detecting the commercials.
jriker1 21 Posted February 14, 2023 Posted February 14, 2023 Thanks I'll give it a try tonight. Out of curiosity, I have the beta version of the Android I guess "phone" app but wasn't there somewhere to get the latest beta of the Android TV app? Thought I saw it in the forum before and now can't find it. Thought enrolling in the beta program thru Google wasn't how it worked anymore and the APK's where somewhere
jriker1 21 Posted February 14, 2023 Posted February 14, 2023 That worked really good. Only issue is the English and Spanish audio are switched but will save that for a separate thread.
