TMCsw 260 Posted October 26, 2022 Posted October 26, 2022 That wasn't a command It's a directory where you would place the ComSkipper.dll file BUT I don't use Docker so I don't know where the directory is in docker.. If you can find the plugins folder in docker then you can place the dll in there... To get the file go to the first post in this thread and and click on the ??current release?? link then copy right click on the comskipper..zip file and copy-link (I'm doing this from memory and hopping OMV works the same, so be kind). NOTE: Caps Matter (i may have ComSkipper (sp?) caps wrong?) Next in a putty session: type wget <paste link here> enter type unzip ComSkipper.zip enter now you will need to move the ComSkipper.dll to the plugin directory in the docker container, sorry i can't help you there. you may need to also use chown emby:emby Comskipper.dll and chmod 644 ComSkipper.dll so it looks the same as the other .dll's ls -l
Dont1982 8 Posted October 26, 2022 Posted October 26, 2022 I am in the process of transferring all my media and switching it to a windows machine which I know how to navigate. I may check back when I get this accomplished. Thank you all for the help.
Film Playlist 8 Posted October 30, 2022 Posted October 30, 2022 (edited) Got this problem while installing. The GIT server is down/timed out. I suppose there are no other alternatives addresses? Edited October 30, 2022 by Film Playlist
TMCsw 260 Posted October 30, 2022 Posted October 30, 2022 Try this: git clone https://github.com/erikkaashoek/Comskip (security change) Note this version may crash (seg fault) often, you may be better off installing from distro. 1
Cheesegeezer 3106 Posted October 30, 2022 Posted October 30, 2022 Is this another cause of new core changes?
roaku 842 Posted October 31, 2022 Posted October 31, 2022 56 minutes ago, Cheesegeezer said: Is this another cause of new core changes? The plugin doesn't provide or use comskip directly. It just reads edl files.
Film Playlist 8 Posted October 31, 2022 Posted October 31, 2022 2 hours ago, TMCsw said: Try this: git clone https://github.com/erikkaashoek/Comskip (security change) Note this version may crash (seg fault) often, you may be better off installing from distro. thank you
iBoss 31 Posted November 7, 2022 Posted November 7, 2022 Hi I have installed ComSkipper Please can any one tell me how to use this plugin with only edl file in my Movies (not recoding contents) to skip 'Violent' scene from a video. Thanks
BillOatman 597 Posted November 7, 2022 Author Posted November 7, 2022 10 hours ago, iBoss said: Hi I have installed ComSkipper Please can any one tell me how to use this plugin with only edl file in my Movies (not recoding contents) to skip 'Violent' scene from a video. Thanks I think it should work with movies but I never tried. You would have to manually create the EDL file for the movie skipping the scenes you desire, and name it as described in the PDF file. I'd try it first just skipping some random time to make sure it works for movies. If it does not, let me know. 1
iBoss 31 Posted November 8, 2022 Posted November 8, 2022 15 hours ago, BillOatman said: I think it should work with movies but I never tried. You would have to manually create the EDL file for the movie skipping the scenes you desire, and name it as described in the PDF file. I'd try it first just skipping some random time to make sure it works for movies. If it does not, let me know. it does not work .. I have just install ComSkipper enable Auto Skip Commercials from the Plugin setting create file with extension edl: 60 120 0 Rename the file same as movie name Movie.mkv Movie.edl
Spaceboy 2573 Posted November 8, 2022 Posted November 8, 2022 53 minutes ago, iBoss said: it does not work .. I have just install ComSkipper enable Auto Skip Commercials from the Plugin setting create file with extension edl: 60 120 0 Rename the file same as movie name Movie.mkv Movie.edl your edl setup looks fine. i don't see any reason why it wouldnt work. you'll probably need to provide logs from when you play the movie
richt 95 Posted November 8, 2022 Posted November 8, 2022 I haven't had any problems with Comskipper and edl files on movies recorded from TV signals. They work fine and are in a separate "movies" library, so this should work without trouble. I do however 'think' I recall that the values in your edl file should have a decimal point and 2 digits to the right of the decimal. Try changing the file to this and see what happens. 60.00 120.00 0
BillOatman 597 Posted November 9, 2022 Author Posted November 9, 2022 On 11/8/2022 at 4:42 AM, iBoss said: it does not work .. I have just install ComSkipper enable Auto Skip Commercials from the Plugin setting create file with extension edl: 60 120 0 Rename the file same as movie name Movie.mkv Movie.edl Could you please turn on debug logging and play the movie past the 60 second mark and send me the log? And don't forget to turn off debug logging after
Deihmos 170 Posted November 12, 2022 Posted November 12, 2022 (edited) Plugin works great. Is there a remote shortcut to jump to the next commercial break? Edited November 13, 2022 by Deihmos
BillOatman 597 Posted November 13, 2022 Author Posted November 13, 2022 22 hours ago, Deihmos said: Plugin works great. Is there a remote shortcut to jump to the next commercial break? Thanks. No it just skips commercials.
Dont1982 8 Posted November 14, 2022 Posted November 14, 2022 Ok I have my windows machine up and running. Have comskipper dll in the plug-ins folder. Have edl. Files for the recordings. Watched one tonight and the commercials are still there, the commercials did not skip. Any help would be appreciated.
BillOatman 597 Posted November 14, 2022 Author Posted November 14, 2022 14 hours ago, Dont1982 said: Ok I have my windows machine up and running. Have comskipper dll in the plug-ins folder. Have edl. Files for the recordings. Watched one tonight and the commercials are still there, the commercials did not skip. Any help would be appreciated. 1) Plugin enabled? 2) edl file named correctly (i.e recording is abcd.ts and the edl is abcd.edl) 3) Look at the logs after playing past a commercial and see if there is any indication as to why it did not skip. 4) If the above does not clear it up, turn debug logging on and play into a commercial and send me the log.
Dont1982 8 Posted November 14, 2022 Posted November 14, 2022 (edited) Ok how do I make sure it is enabled? Edit: It is enabled to automatically skip commercials. EDL files are names just like the video files. attached is the log file embyserver (1).txt Edited November 15, 2022 by Dont1982
BillOatman 597 Posted November 15, 2022 Author Posted November 15, 2022 10 hours ago, Dont1982 said: Ok how do I make sure it is enabled? Edit: It is enabled to automatically skip commercials. EDL files are names just like the video files. attached is the log file embyserver (1).txt 8.29 MB · 0 downloads 2022-11-14 16:55:45.251 Debug Com Skipper: Playback Session = 0fb8f187baac11b89d3cb664a7e5ffd3 Path = E:\TV Shows\The Bold and the Beautiful (1987)\Season 36\The Bold and the Beautiful S36E34.mp4 2022-11-14 16:55:45.251 Debug Com Skipper: Media File: E:\TV Shows\The Bold and the Beautiful (1987)\Season 36\The Bold and the Beautiful S36E34.mp4 EDL file E:\TV Shows\The Bold and the Beautiful (1987)\Season 36\The Bold and the Beautiful S36E34.edl 2022-11-14 16:55:45.251 Info Server: http/1.1 Response 204 to host3. Time: 6ms. http://192.168.0.108:8096/emby/Sessions/Playing 2022-11-14 16:55:45.251 Debug Com Skipper: Comskip EDL file [E:\TV Shows\The Bold and the Beautiful (1987)\Season 36\The Bold and the Beautiful S36E34.edl] does not exist. It cannot find the EDL file.
Dont1982 8 Posted November 15, 2022 Posted November 15, 2022 It is is the same folder as the video file.
BillOatman 597 Posted November 15, 2022 Author Posted November 15, 2022 7 hours ago, Dont1982 said: It is is the same folder as the video file. The MS documentation for the call that tests for the files existence says: Quote If the caller does not have sufficient permissions to read the specified file, no exception is thrown and the method returns false regardless of the existence of path. That's the only thing I can see that could cause that error.
wstewart 9 Posted November 17, 2022 Posted November 17, 2022 (edited) deleted Edited November 17, 2022 by wstewart
iBoss 31 Posted November 17, 2022 Posted November 17, 2022 (edited) Hi this is the error I have: Error Com Skipper: Could not parse EDL file /home/xxxx/xxxx/xxxx/xxxxx.edl. Exception: Index was outside the bounds of the array if you want I can share the whole log file I use this format: 60.00 120.00 0 Thanks Edited November 17, 2022 by iBoss
BillOatman 597 Posted November 17, 2022 Author Posted November 17, 2022 (edited) 7 hours ago, iBoss said: Hi this is the error I have: Error Com Skipper: Could not parse EDL file /home/xxxx/xxxx/xxxx/xxxxx.edl. Exception: Index was outside the bounds of the array if you want I can share the whole log file I use this format: 60.00 120.00 0 Thanks Could you just send the edl file please. Plus, what generated the file? Also, if you have spaces between the values, they need to be tabs. Edited November 17, 2022 by BillOatman
iBoss 31 Posted November 18, 2022 Posted November 18, 2022 23 hours ago, BillOatman said: Could you just send the edl file please. Plus, what generated the file? Also, if you have spaces between the values, they need to be tabs. I'm the one who create the file Yes now is working when I use tabs for spaces Many thanks I have another request if that possible ... can we make check box to enable the skipper for the movie before play it?
