BillOatman 597 Posted May 16, 2022 Author Posted May 16, 2022 5 hours ago, crusher11 said: I've managed to set up comskip on my Synology, and run it on a recording, but it's only produced a TXT file, not an EDL file. It's also deleting the logo file, so it doesn't seem to be using the ini that's present in its folder. Not sure what's going on here? Be specific and specify the ini file to use in the command line option --ini=comskip.ini
BillOatman 597 Posted May 16, 2022 Author Posted May 16, 2022 3 hours ago, Spaceboy said: post your comskip.ini. otherwise we're just guessing. there was a pdf around somewhere which gave some tips but i don't see it anymore The PDF is in the release zip file. Here it is. Commercial Skipper Plugin.pdf
crusher11 1145 Posted May 16, 2022 Posted May 16, 2022 3 minutes ago, BillOatman said: Be specific and specify the ini file to use in the command line option --ini=comskip.ini I'm running on a Synology NAS, not windows. I've just set it to run comskip in the post-processing section. I can't modify, delete or replace the ini file because WinSCP keeps throwing permission errors. I vaguely remember there being a trick to logging in as root but I've long ago forgotten it. @FrostByte?
FrostByte 5456 Posted May 16, 2022 Posted May 16, 2022 Yes, if admin doesn't do the trick then you can configure WinSCP to use superuser 1
crusher11 1145 Posted May 16, 2022 Posted May 16, 2022 Yep, that did it. I'll set another recording and see how it goes, although I've still not done anything to specify the INI file because I don't know how to do that.
crusher11 1145 Posted May 17, 2022 Posted May 17, 2022 Okay, so I've figured out a thing in PuTTY that will run it correctly, and I get an EDL file. I'm just not sure how to have that run automatically, through the equivalent of a batch file, or include the path as a variable. @FrostByte?
crusher11 1145 Posted May 18, 2022 Posted May 18, 2022 I created a .sh file and put that in my comskip directory, and set the post-processing step to use that instead of comskip itself. It didn't do anything though. #!/bin/sh comskip --ini=../var/comskip.ini "${path}"
Q-Droid 1011 Posted May 18, 2022 Posted May 18, 2022 (edited) 6 hours ago, crusher11 said: I created a .sh file and put that in my comskip directory, and set the post-processing step to use that instead of comskip itself. It didn't do anything though. #!/bin/sh comskip --ini=../var/comskip.ini "${path}" Change your .sh file to: #!/bin/sh comskip --ini=../var/comskip.ini "${1}" Your original script is assuming that the file comskip.ini can be found by using a location relative to where the script is running from. You might also have to adjust the --ini entry to use a full path to the comskip.ini file. Edited May 18, 2022 by Q-Droid
crusher11 1145 Posted May 18, 2022 Posted May 18, 2022 I have comskip/var/comskip.ini, comskip/bin/comskip, and comskip/bin/comskip.sh, so a relative path should be fine right?
crusher11 1145 Posted May 18, 2022 Posted May 18, 2022 (edited) 2 hours ago, Q-Droid said: Change your .sh file to: #!/bin/sh comskip --ini=../var/comskip.ini "${1}" Your original script is assuming that the file comskip.ini can be found by using a location relative to where the script is running from. You might also have to adjust the --ini entry to use a full path to the comskip.ini file. 2022-05-18 23:09:43.867 Info LiveTV: Running recording post processor /volume1/@appstore/comskip/bin/comskip.sh /volume1/Emby Libraries/Recordings/Midsomer Murders (1997)/Season 5/Midsomer Murders S05E04 Murder On St Malley's Day.ts 2022-05-18 23:09:43.872 Error LiveTV: Error running recording post processor *** Error Report *** Version: 4.7.0.35 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /volume1/Emby/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 4.4.59+ (root@build2) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25556 SMP PREEMPT Sat Aug 28 02:16:43 CST 2021 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (13): An error occurred trying to start process '/volume1/@appstore/comskip/bin/comskip.sh' with working directory '/'. Permission denied at System.Diagnostics.Process.ForkAndExecProcess(ProcessStartInfo startInfo, String resolvedFilename, String[] argv, String[] envp, String cwd, Boolean setCredentials, UInt32 userId, UInt32 groupId, UInt32[] groups, Int32& stdinFd, Int32& stdoutFd, Int32& stderrFd, Boolean usesTerminal, Boolean throwOnNoExec) at System.Diagnostics.Process.StartCore(ProcessStartInfo startInfo) at Emby.Server.Implementations.Diagnostics.CommonProcess.Start() at Emby.LiveTV.EmbyTV.PostProcessRecording(ActiveRecordingInfo recordingInfo) Source: System.Diagnostics.Process TargetSite: Boolean ForkAndExecProcess(System.Diagnostics.ProcessStartInfo, System.String, System.String[], System.String[], System.String, Boolean, UInt32, UInt32, UInt32[], Int32 ByRef, Int32 ByRef, Int32 ByRef, Boolean, Boolean) Edited May 18, 2022 by crusher11
Q-Droid 1011 Posted May 18, 2022 Posted May 18, 2022 48 minutes ago, crusher11 said: I have comskip/var/comskip.ini, comskip/bin/comskip, and comskip/bin/comskip.sh, so a relative path should be fine right? I would say no. I'm making the assumption that you're running this script from Emby -> Live TV/DVR -> Advanced -> Recording post processing. The script will run under the context of the Emby server and current working directory is not going to be the comskip location. So it will not be able to derive the ini file location using a relative path. 5 minutes ago, crusher11 said: System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (13): An error occurred trying to start process '/volume1/@appstore/comskip/bin/comskip.sh' with working directory '/'. Permission denied It looks like the emby server process does not have permissions to access and execute the script. Once you get that resolved then the path to comskip.sh above should be included in the script for both the comskip command and the path to the ini file. You could do this in the script: #!/bin/sh CSDIR=$(dirname $0) ${CSDIR}/comskip --ini=${CSDIR}/../var/comskip.ini "${1}"
crusher11 1145 Posted May 18, 2022 Posted May 18, 2022 Just now, Q-Droid said: I would say no. I'm making the assumption that you're running this script from Emby -> Live TV/DVR -> Advanced -> Recording post processing. The script will run under the context of the Emby server and current working directory is not going to be the comskip location. So it will not be able to derive the ini file location using a relative path. It looks like the emby server process does not have permissions to access and execute the script. Once you get that resolved then the path to comskip.sh above should be included in the script for both the comskip command and the path to the ini file. You could do this in the script: #!/bin/sh CSDIR=$(dirname $0) ${CSDIR}/comskip --ini=${CSDIR}/../var/comskip.ini "${1}" Ah. I figured the script would run from where the script was saved. Am I supposed to replace "dirname" with a path of some sort there? Or just copy and paste that as-is? I have no idea how to resolve the permission issue.
Q-Droid 1011 Posted May 18, 2022 Posted May 18, 2022 "dirname" is an actual command, copy/paste as is. You'll have to work through the Syno console to give the emby server process owner what it needs to access that location and execute that script. I can't give you details as I don't use Synology.
crusher11 1145 Posted May 18, 2022 Posted May 18, 2022 1 minute ago, Q-Droid said: "dirname" is an actual command, copy/paste as is. You'll have to work through the Syno console to give the emby server process owner what it needs to access that location and execute that script. I can't give you details as I don't use Synology. But what owns the process and what location does it need access to? I'm not even sure what I'm looking for here.
BillOatman 597 Posted May 21, 2022 Author Posted May 21, 2022 (edited) New release in first post. Upgrade to MediaBrowser.Server.Core to 4.7.0.30 Required a small code change for compatibility with the latest server. Edited May 21, 2022 by BillOatman 1
Spaceboy 2573 Posted May 21, 2022 Posted May 21, 2022 4 hours ago, BillOatman said: New release in first post. Upgrade to MediaBrowser.Server.Core to 4.7.0.30 Required a small code change for compatibility with the latest server. i only see comskip.ini in the first post?
samuelqwe 317 Posted May 21, 2022 Posted May 21, 2022 4 minutes ago, Spaceboy said: i only see comskip.ini in the first post? You have to click the Current Release link right above the release notes. 1
Spaceboy 2573 Posted May 21, 2022 Posted May 21, 2022 2 minutes ago, samuelqwe said: You have to click the Current Release link right above the release notes. i knew i must be doing something dense
abescalamis 88 Posted May 30, 2022 Posted May 30, 2022 On 5/18/2022 at 8:47 AM, crusher11 said: But what owns the process and what location does it need access to? I'm not even sure what I'm looking for here. If you manage to run it on synology NAS and get it working, please share how you did it, I was looking into using comskipper on docker, when I came across this topic and saw that you manage to install it on a NAS. Thank you
abescalamis 88 Posted May 30, 2022 Posted May 30, 2022 (edited) On 5/18/2022 at 8:47 AM, crusher11 said: But what owns the process and what location does it need access to? I'm not even sure what I'm looking for here. Login using putty and enter the following commands and that should be it, also make go to the shared folder settings and you give permission to emby to access to the directory where the .sh and .ini are saved. sudo chown -R emby:emby /volume1/@appdata/EmbyServer/plugins/ComSkipper.dll sudo chmod -R 777 /volume1/@appdata/EmbyServer/plugins/ComSkipper.dll Edited May 30, 2022 by abescalamis
abescalamis 88 Posted May 30, 2022 Posted May 30, 2022 (edited) The only thing I need help with is the path to enter in the .ssh file tried this: #!/bin/sh CSDIR=$(dirname $0) ${CSDIR}/AMC --ini=${CSDIR}/../Scripts/comskipper.ini "${1}" The .ssh is stored in /volume1/AMC/Scripts/comskipper.sh The .ini is stored in the same directory /volume1/AMC/Scripts/comskipper.ini Edited May 30, 2022 by abescalamis
crusher11 1145 Posted May 30, 2022 Posted May 30, 2022 5 hours ago, abescalamis said: If you manage to run it on synology NAS and get it working, please share how you did it, I was looking into using comskipper on docker, when I came across this topic and saw that you manage to install it on a NAS. Thank you
abescalamis 88 Posted May 30, 2022 Posted May 30, 2022 (edited) 1 hour ago, crusher11 said: What I did was to 1) move the plugin ComSkipper.dll to /volume1/@appdata/EmbyServer/plugins/ComSkipper.dll, Changed permissions owner and everything. 2) created a SSH file on /volume1/AMC/Scripts/comskipper.sh #!/bin/sh /volume1/AMC/Scripts --ini=/volume1/AMC/Scripts/comskipper.ini "${1}" 3) moved the default .ini to same directory as the .ssh file /volume1/AMC/Scripts/ 4)changed What would you suggest, I'm just confused at the directories you used for the ini. and .ssh Edited May 30, 2022 by abescalamis
crusher11 1145 Posted May 30, 2022 Posted May 30, 2022 I'm not using an .sh file at all anymore, I'm just pointing the post processing at comskip directly.
