pir8radio 1313 Posted January 7, 2022 Posted January 7, 2022 (edited) 8 hours ago, Bagul said: Hello, I have already compared. The proxy_send_timeout and proxy_read_timeout options are not specified and according to the nginx documentation the default values are 60 seconds. I will try to remove the options to leave the default one but otherwise the rest is the same. did you compare? because i'm pretty sure I set mine high lol.. you don't want to go too high, maybe look a little closer at my example config... I thought @Luke we talked about this, nginx is happy as long as data is flowing, so a simple transaction over websocket once a min is good enough.. like a ping.. just send anything.. lol but i have not seen issues with it set to 1 hour.. that's high, I wouldn't do that on a busy commercial nginx server, but for your home should be just fine. proxy_connect_timeout 1h; proxy_send_timeout 1h; proxy_read_timeout 1h; tcp_nodelay on; ## Sends data as fast as it can not buffering large chunks, saves about 200ms per request. Edited January 7, 2022 by pir8radio
Bagul 182 Posted January 8, 2022 Author Posted January 8, 2022 (edited) Hello, indeed I saw plenty, too many, tutorials on the forum including yours and it was indeed specified. Sorry for my mistake. I put it on an hour as you did and I will see if my problem disappears. Sorry again for the mistake. I will also try with traefik (https://hub.docker.com/_/traefik) to see if the problem is the same. Edited January 8, 2022 by Bagul 1
pir8radio 1313 Posted January 10, 2022 Posted January 10, 2022 On 1/7/2022 at 6:06 PM, Bagul said: Hello, indeed I saw plenty, too many, tutorials on the forum including yours and it was indeed specified. Sorry for my mistake. I put it on an hour as you did and I will see if my problem disappears. Sorry again for the mistake. I will also try with traefik (https://hub.docker.com/_/traefik) to see if the problem is the same. you are fine, i was joking around.. my humor is not always understood..
Bagul 182 Posted January 10, 2022 Author Posted January 10, 2022 55 minutes ago, pir8radio said: you are fine, i was joking around.. my humor is not always understood.. No, It's ok it's ok. I just recognize my mistake. I tried Traefik. I spent one night reading the documentation and I made my little settings and for the moment the problem is not present anymore while leaving the timeout settings as originally. By doing benchmarks nginx is not necessarily better so the configuration with traefik suits me perfectly.
