MarkTechnics 0 Posted December 19, 2021 Posted December 19, 2021 Hello, I noticed that, when I want to play a full album, the next song will not be played at my Technics SL-G700 streamer. The playing of the album will be executed from the Sndroid app, Edge and Firefox browser. All have the same behavior. When I play the album from the browser and listen it at the local speakers, it will play the next song. So because of that, I thought it has something to do with DLNA. I created a separate DLNA profile for the streamer, but that does not help. Emby is installed on a Synology DS220+ with DSM DSM 7.0.1-42218. The logfiles were included. Thank you in advance for your help! hardware_detection-63775547944.txt ffmpeg-transcode-f7f08c16-bcfb-490d-ae45-7c639050efdf_1.txt ffmpeg-transcode-8dd88be1-164b-4f4b-ab69-3d5d4e05acdb_1.txt embyserver.txt
Luke 42237 Posted December 20, 2021 Posted December 20, 2021 Hi, we'll take a look at this. Thanks for reporting.
MarkTechnics 0 Posted December 20, 2021 Author Posted December 20, 2021 Update: When I stream to Chromecast, everything is working fine. So playing the next song and showing the playbar.
