LJDCDC 2 Posted December 19, 2021 Posted December 19, 2021 Hi, a few days ago my server stopped reading the new files I add to my libraries, this is happening in all libraries, both series and movies. Tried to restart the server, the machine, but nothing. Example: I added a new movie in my movie folder, Embu didn't read that file, not even in manual mode. embyserver.txt
Happy2Play 9802 Posted December 19, 2021 Posted December 19, 2021 13 minutes ago, LJDCDC said: Hi, a few days ago my server stopped reading the new files I add to my libraries, this is happening in all libraries, both series and movies. Tried to restart the server, the machine, but nothing. Example: I added a new movie in my movie folder, Embu didn't read that file, not even in manual mode. embyserver.txt 7.21 MB · 0 downloads Best guess drive letter change. Could not find a part of the path 'S:\Filmes 03'. Did you add something to this library? Has the drive letter changed?
LJDCDC 2 Posted December 19, 2021 Author Posted December 19, 2021 6 minutes ago, Happy2Play said: Best guess drive letter change. Could not find a part of the path 'S:\Filmes 03'. Did you add something to this library? Has the drive letter changed? The drive letter hasn't changed, I've been using it forever AThis folder in question "S:\Filmes 03" is still empty, to which for example I added new files would be "S:\Filmes 01"
Solution Happy2Play 9802 Posted December 19, 2021 Solution Posted December 19, 2021 5 minutes ago, LJDCDC said: The drive letter hasn't changed, I've been using it forever AThis folder in question "S:\Filmes 03" is still empty, to which for example I added new files would be "S:\Filmes 01" What did you add to Filmes 1? But there is an issue with Filmes 3. 2021-12-18 15:29:16.908 Info LibraryMonitor: Skipping realtime monitor for S:\Filmes 03 because the path does not exist But lots of errors for Filmes 3. If it is empty does removing this library folder, make any difference? 1
LJDCDC 2 Posted December 19, 2021 Author Posted December 19, 2021 33 minutes ago, Happy2Play said: What did you add to Filmes 1? But there is an issue with Filmes 3. 2021-12-18 15:29:16.908 Info LibraryMonitor: Skipping realtime monitor for S:\Filmes 03 because the path does not exist But lots of errors for Filmes 3. If it is empty does removing this library folder, make any difference? I removed the folder to test and the emby actually found the new movies, I'll leave the folder out of the library until I start using it. I think all right, thanks for the assistance.
