chudak 24 Posted December 17, 2021 Posted December 17, 2021 Hello all I needed to map my channels with new IPTV list and saw many new improvements in this area. It's great! Good job @Luke ! One thing I wish existed. Say I have channels that have to be manually mapped as in here: Right now when I select Guide data source, I have to look thru all options in the drop-down below to do a proper mapping. I wish Emby had an option to perform an automatic search and propose matches. That'd be really cool ! Thx
Carlo 4561 Posted December 18, 2021 Posted December 18, 2021 If the provider had a decent guide source it would match the channel list and you wouldn't have to do this. Kind of like how it "just works" for cable TV and Emby Guide data. But, I'll know that's a pipe dream for these kinds of services. So let me ask you what exactly would it try to use to match the channel to the guide?
chudak 24 Posted December 18, 2021 Author Posted December 18, 2021 1 minute ago, cayars said: If the provider had a decent guide source it would match the channel list and you wouldn't have to do this. Kind of like how it "just works" for cable TV and Emby Guide data. But, I'll know that's a pipe dream for these kinds of services. So let me ask you what exactly would it try to use to match the channel to the guide? From the screen above, I would add a button “search for possible matches”, after click it’d take the “One HD” string and compare it against the list loaded in Guide data channel Found matches would be shown in a new list, or else and then user would be able to select from those options makes sense?
Carlo 4561 Posted December 18, 2021 Posted December 18, 2021 Oh that's different. You want a manual search and I agree that could be handy. I just didn't know what an automatic one would do as Emby has already tried matching a couple ways. Just handling the dialog a slightly different way would work as well. If it weren't a drop down list box that disappears but you had the whole list open you could CTRL-F to use the browsers normal find function which could be a very easy method.
