A8HTPC 38 Posted September 14, 2014 Posted September 14, 2014 I noticed this last night. Not sure how long its been going on though. "TV" Shows TV series like its supposed to Problem areas "Movies" when clicked on is supposed to show "ALL MOVIES". Though it will only show my Collections and nothing else. These two options are dependent on which one I go to first. If I click on bluray, then both the BluRay and DVD options will show BluRay movies. If I want to see DVD movies, I have to click on TV to show tv movies and then go back to DVD to show DVD movies, which then after looking at DVD, if I click on BluRay I only see DVD movies. Going to TV seems to reset the view when wanting to switch from DVD to BluRay. "BluRay" will show either, BluRay movies, or DVD movies. "DVD" will show either, DVD movies or BluRay Movies.
ab123ga 18 Posted September 21, 2014 Posted September 21, 2014 I'm having a similar but different issue. My list shows Family 2d, Movies 2D, Documentaries, Classics, (a few more). No matter which I hit, I get Family 2d movies only. Ver 3.0.5362.41853
A8HTPC 38 Posted September 28, 2014 Author Posted September 28, 2014 (edited) Some troubleshooting I have been trying to figure out why clicking on "Movies" in the list above only shows Movie Collections in my Boxsets folder. I did find out the "Movies" menu option only appears when I have collections "checked" regardless of anything else and "Movies" defaults to Movie Collections. Though if I click on TV and then click on either "Bluray" or "DVD", "Movies" will show either Bluray movies or DVD Movies Video of problem Now only BluRay and DVD checked Collections, BluRay and DVD checked Edited September 28, 2014 by A8HTPC
A8HTPC 38 Posted October 12, 2014 Author Posted October 12, 2014 This is still going on. Server 3.0.5395.0 Server Log Theater 3.0.5377.16926 Theater Log
