Nacher 0 Posted December 17, 2021 Posted December 17, 2021 Hola a todos. Espero encontrar ayuda por aquí porque me estoy volviendo loco. He instalado Emby Server en Nvidia Shield Pro. Todo correcto pero en el momento de crear la carpeta de la biblioteca aparece el error "Se produjo un error al agregar la ruta del medio. Por favor, asegúrese de que la ruta sea válida y que el proceso del servidor Emby tenga acceso a esa ubicación.". La ruta la reconoce pero cuando le doy al ok para cerrar la ventana aparece continuamente ese fallo. Mil gracias.
Carlo 4561 Posted December 17, 2021 Posted December 17, 2021 Hi, @After The Shield TV is unique in setup compared to most other OS requirements for Emby. You did not comment on where the media is stored which could be a local USB3 HDD or a network location. We have instructions for installation in our Knowledge Base that you should take a look at: https://support.emby.media/support/solutions/articles/44001849875-server-installation-on-shield-tv Pay attention to step 8 if using local USB3 connections. If you are using network attached storage you will want to follow this KB article: https://support.emby.media/support/solutions/articles/44002058102-android-tv-storage-attachment Let us know if this helps resolve your problem. If it does not, please give us more information about your setup and what the exact problem is so we can assist you. Thanks
