Viktor Manuel 6 Posted December 16, 2021 Posted December 16, 2021 Problema de desplazamiento hacia abajo y hacia arriba en las bibliotecas
Luke 42238 Posted December 16, 2021 Posted December 16, 2021 Hi there, can you please describe this in more detail, perhaps showing a screenshot? Thanks.
Viktor Manuel 6 Posted December 16, 2021 Author Posted December 16, 2021 cuando bajas hacia abajo o arriba solo baja y sube 2 filas
Luke 42238 Posted December 16, 2021 Posted December 16, 2021 Can you please describe this in more detail? Thanks.
arthurmv 14 Posted December 17, 2021 Posted December 17, 2021 6 minutes ago, Viktor Manuel said: cuando bajas hacia abajo o arriba solo baja y sube 2 filas Esto te pasa al arrastrar la barra de desplazamiento de la derecha? Si el problema es girando la rueda del mouse talvez puedas aumentar la sensibilidad de tu mouse.
Viktor Manuel 6 Posted December 17, 2021 Author Posted December 17, 2021 No con los botones, voy a intentar desinstalar la app y volver a instalarla
KoqueSilva 2 Posted December 17, 2021 Posted December 17, 2021 Hello I'm having the same problem I have a LG TV, I'm having the same slip problem after the last update. Details: When I go down, it doesn't load, only after I click the remote up and then to the right side of the movie list, it loads.
Viktor Manuel 6 Posted December 17, 2021 Author Posted December 17, 2021 (edited) Reinstale la App y se soluciono el problema. Elimine la app y vuelva a instalarla Edited December 17, 2021 by Viktor Manuel
KoqueSilva 2 Posted December 17, 2021 Posted December 17, 2021 1 minute ago, Viktor Manuel said: Reinstale la App y se soluciono el problema. Elimine la app y vuelva a instalarla So I already did the installation thinking it would work but for me it still doesn't work. Model: LG Smart TV (43LK5750PSA)
Viktor Manuel 6 Posted December 17, 2021 Author Posted December 17, 2021 (edited) Disculpa, el problema me volvio a suceder en este momento probando, parece ser un error en la nueva actualizacion, sin enbargo tengo otros LG y no me sucede Edited December 17, 2021 by Viktor Manuel
