Guest Posted December 16, 2021 Posted December 16, 2021 (edited) When I try to download a movie or show on Emby Theater through the Windows store it says it downloads but then it stays suck in transferring. If you go to downloads section you can click on the folder but then nothing is there, it doesn't work regardless if I download in orginal quality. Edited December 16, 2021 by Figment123456
Guest Posted December 17, 2021 Posted December 17, 2021 @LukeAm I doing something wrong? Or is offline playback not supported?
Luke 42239 Posted December 28, 2021 Posted December 28, 2021 @Figment123456 did the downloads finish?
Guest Posted December 28, 2021 Posted December 28, 2021 Yeah the downloads finished but it takes a very long time for it to show as transfered so it will show up in downloads section.
Luke 42239 Posted December 28, 2021 Posted December 28, 2021 We're looking into improving it. Thanks for the feedback.
