Tarek369 1 Posted December 16, 2021 Posted December 16, 2021 Emby was working great on my LG tv, today I updated it to v 1.0.31, and when I scroll down or up, the cursor, which selected on movie poster disappear when scroll down, so I can't scroll anymore, I have to press up many times till cursor appear on poster then continue up and down. Is there away to install the older version ? 1
Luke 42237 Posted December 16, 2021 Posted December 16, 2021 Hi, what model do you have, and what version of WebOS does it run?
falihax 0 Posted December 16, 2021 Posted December 16, 2021 I have the same issue. Using the scroll wheel is okay for scrolling down the list but using the up and down buttons the screen stops scrolling once it passes the last visible row on the screen. Moving up so the highlight border appears on the bottom visible poster again then lets me scroll down one more row, so once you have reached the point it does not scroll you must press up/down/down to move one more row down, and keep repeating (or the opposite to scroll up). I use a harmony remote and so navigate with buttons and not a scroll wheel. It did not do this on the previous version and so ideally I would like to go back to that version but don't think it is possible. TV Model: LG 49SK8500PLA WebOS: 4.4.0-9 (goldilocks-gorce)
Generalfuzuki 1 Posted December 16, 2021 Posted December 16, 2021 (edited) Update: it looks like this is intentional as when you select a show it shows the info are the bottom of the screen. Seems to have cropped the guid data window too. Take a few secs to load and then chops it off. Lg UJ635 software version 06.00.20 Edited December 16, 2021 by Generalfuzuki Update 1
Luke 42237 Posted December 16, 2021 Posted December 16, 2021 6 minutes ago, Generalfuzuki said: Seems to have cropped the guid data window too. Take a few secs to load and then chops it off. Lg UJ635 software version 06.00.20 This screen is by design. The space underneath is used to display information about the current selected program.
Stan Guiseppe 8 Posted December 17, 2021 Posted December 17, 2021 Hi, I'm having the same issue as Tarek369. Was working fine until I updated today. Green outline disappears if you try to scroll down. TV: OLED65B8STB WebOS: 5.40.09
DonMilne 4 Posted December 17, 2021 Posted December 17, 2021 (edited) Same here. WebOS (on 55" OLED tv) yesterday told me that Emby app needed to be updated. Now I find that when viewing info for a movie I'm about to watch that the "page" doesn't follow the green highlight box as I move it down, e.g. to look at the cast list, so green box simply seems to disappear. Very weird at first. Then if I click cursor right the page jumps up, bringing the green box into view. Hit cursor right again and it jumps a little more. Then that's it. It behaves as if it's only allowed to scroll the page when I hit a cursor key, AND it can only scroll a little bit at a time, so it takes several attempts to bring the green box fully to its final position. As a programmer myself, this seems like a basic navigation bug, a decoupling of cursor position with current viewing portion of the (html?) page. Edit: LG OLED55B8PA (2018). WebOS 5.40.09. Edited December 17, 2021 by DonMilne
nanuk 36 Posted December 17, 2021 Posted December 17, 2021 (edited) Same Scroll Problem here > LG 55UJ6309 Edited December 17, 2021 by nanuk
halvdan 4 Posted December 17, 2021 Posted December 17, 2021 Same problem here. Previous version did not have this problem. LG 49UK6470 WebOs 05.40.09
KoqueSilva 2 Posted December 17, 2021 Posted December 17, 2021 Hello I'm having the same problem I have a LG TV, I'm having the same slip problem after the last update. Details: When I go down, it doesn't load, only after I click the remote up and then to the right side of the movie list, it loads.
Luke 42237 Posted December 18, 2021 Posted December 18, 2021 We're looking into it. Thanks for reporting.
majorsl 23 Posted December 18, 2021 Posted December 18, 2021 Ah, came here to post the same issue. Glad you're already on top of it!
Generalfuzuki 1 Posted December 19, 2021 Posted December 19, 2021 On 16/12/2021 at 22:55, Luke said: This screen is by design. The space underneath is used to display information about the current selected program. Apart from the scroll issue is it possible to have this as an option or reduce the cell size, it is a bit annoying only being able to see four listings at once or can I roll back versions ? thanks
DonMilne 4 Posted December 19, 2021 Posted December 19, 2021 @Generalfuzuki: it seems to me you are discussing a different problem. Everyone else, including the OP, is talking about a problem when browsing movie entries. Not a problem using a TV tuner.
eimantasz 3 Posted December 28, 2021 Posted December 28, 2021 Hello, The same problem here. Can't use scroll normally with cursor keys up and down, only wheel scroll helps, but it's too slow. WebOS 05.40.09 LG OLED55C8PLA Emby 1.0.31 Regards
eimantasz 3 Posted December 28, 2021 Posted December 28, 2021 BTW, Another LG TV scrolling works fine. WebOS 04.30.50 LG 43NANO793NE Emby 1.0.31
SamES 1084 Posted December 28, 2021 Posted December 28, 2021 I think your 'webOS' versions are actually firmware versions, not webos versions. If you go a bit deeper in the 'About this TV' menu you will eventually get to the webos version I believe that OLED55C8PLA - webos 4 or 4.5 43NANO793NE - webos 5 This website is good for providing the actual OS versions https://opensource.lge.com/index Anyway, back to your comment, this scrolling issue only affects webos 4.x versions and is fixed for the next release.
DonMilne 4 Posted December 28, 2021 Posted December 28, 2021 Quote this scrolling issue only affects webos 4.x versions and is fixed for the next release. That's very good news thank you. Hopefully this new release is pushed soon, as the movie pages are difficult to use at the moment.
Stan Guiseppe 8 Posted December 28, 2021 Posted December 28, 2021 13 hours ago, SamES said: I think your 'webOS' versions are actually firmware versions, not webos versions. If you go a bit deeper in the 'About this TV' menu you will eventually get to the webos version I believe that OLED55C8PLA - webos 4 or 4.5 43NANO793NE - webos 5 This is correct, I checked again and: TV: OLED65B8STB WebOS: 4.4.0-9. Software version: 5.40.09
marky9074 1 Posted December 31, 2021 Posted December 31, 2021 (edited) Have the same problem on a 2018 OLED65C8PLA. My daughters noted that if you scroll right or left, then up or down it works. So one scroll right one scroll down (basically any single scroll in the horizontal axis then one in the vertical) rinse and repeat. At least it is a workaround until a fix is made. Edited December 31, 2021 by marky9074
Pezza371887 1 Posted January 2, 2022 Posted January 2, 2022 Same issue, cannot scroll down. Mine is a 43UK6750PLD 05.40.09 WebOS 4.4.0-9
guymyer 1 Posted January 17, 2022 Posted January 17, 2022 What's the status on a fix for this issue? I have 3 LG TVs and they all are having this issue with emby.
marky9074 1 Posted January 17, 2022 Posted January 17, 2022 I note that all my 32" LG's just updated, but the 65" one with the issue has not. One thing that I wonder if others have seen, is that it takes forever for the main screen to download the covers and so on as soon as you open the client. If I restart the TV and then open the Emby app they get pulled and show up straight away. This only happens on the 65" and not on all the lower spec 32" models.....
Luke 42237 Posted January 18, 2022 Posted January 18, 2022 3 hours ago, guymyer said: What's the status on a fix for this issue? I have 3 LG TVs and they all are having this issue with emby. We've got it resolved. We're just trying to get the update through LG review. Thanks. 1
