Pkanarki 2 Posted December 16, 2021 Posted December 16, 2021 I have a really weird problem: I use a shield Tv on my lan, mostly for live TV with m3u file fetching .ts files. When I livestream on lan via shield, I cannot playback movie from library externally/wan on android app. I can browse the library, but when I choose playback, I get spinning wheel and when I go back all folders/movies etc are gone. It's like connection is lost after that and I cannot logout or anything. After that it is not possible to login anymore from wan anymore until I have connected to lan and then disconnect lan. The android app works fine if I am not using the shield on lan. Problem does NOT happen when I use the chrome browser on my android phone and shield lab at same time. So strange I am running latest emby server on Windows 10 Pro, with caddy as reverse proxy with let's encrypt certificates. I have a vague suspicion that it could maybe also might be caddy causing troubles. Emby Android app is latest version from Google play. Best regards
Solution Pkanarki 2 Posted December 16, 2021 Author Solution Posted December 16, 2021 Disregard my topmessage. Problem. Was caused by running a zerotier server on the same pc as the reverse proxy(caddy). Removing/uninstalling zerotier made playback on android app work again. But I do not know why.
