Nastream 5 Posted December 14, 2021 Posted December 14, 2021 can you add the limit to 100 for the series tv please ? it works well for movies thank you for this plugin !
Nastream 5 Posted December 14, 2021 Author Posted December 14, 2021 2 hours ago, Nastream said: can you add the limit to 100 for the series tv please ? it works well for movies thank you for this plugin ! Hello, sorry its for plugin EmbyCON escuse me im use google trad
TeamB 2440 Posted December 14, 2021 Posted December 14, 2021 I will add this. What version are you using Kodi 18 or Kodi 19?
Nastream 5 Posted December 15, 2021 Author Posted December 15, 2021 hello, im using kodi 19.3 if you can also increase to 200 views (100 is good but if we can have a little more choice it would be really great) thank you @TeamB
TeamB 2440 Posted December 16, 2021 Posted December 16, 2021 This change has been released as beta in both the Kodi 18 and 19 branches - add paging to TV Shows - increase max item per page to 200 2
Nastream 5 Posted December 17, 2021 Author Posted December 17, 2021 On 14/12/2021 at 17:09, Nastream said: pouvez-vous ajouter la limite à 100 pour la série tv s'il vous plaît ? ça marche bien pour les films merci pour ce plugin ! thank you very much @Équipe B it's perfect
