Spoonsy1480 2 Posted December 13, 2021 Posted December 13, 2021 I have added my hdhomerun yes I have premium but when I go to guide date but in my country then go to my postcode it all goes smooth but when I go to lineup there is nothing. It says no options?
ebr 16332 Posted December 13, 2021 Posted December 13, 2021 Hi. Our built-in guide data is only available in the US, Canada and UK. In other countries, you will need to choose one of the other sources.
Spoonsy1480 2 Posted December 13, 2021 Author Posted December 13, 2021 Sorry I forgot to say United Kingdom
Spoonsy1480 2 Posted December 13, 2021 Author Posted December 13, 2021 30 minutes ago, Spoonsy1480 said: Sorry I forgot to say United Kingdom
ebr 16332 Posted December 13, 2021 Posted December 13, 2021 Hi. Make sure to enter only the first part of the post code.
Spoonsy1480 2 Posted December 13, 2021 Author Posted December 13, 2021 I have BA14 and still nothing in lineups
ebr 16332 Posted December 13, 2021 Posted December 13, 2021 Working for me: Did you tab off of the post code field? If you open the browser console, are there any errors there?
Spoonsy1480 2 Posted December 13, 2021 Author Posted December 13, 2021 12 minutes ago, ebr said: Working for me: Did you tab off of the post code field? If you open the browser console, are there any errors there? This is what I get
Spoonsy1480 2 Posted December 13, 2021 Author Posted December 13, 2021 My mistake my premium has run out
ebr 16332 Posted December 13, 2021 Posted December 13, 2021 11 minutes ago, Spoonsy1480 said: My mistake my premium has run out Okay. We need to do a better job of displaying that as the cause... or just not let you into this screen.
Spoonsy1480 2 Posted December 13, 2021 Author Posted December 13, 2021 I had dvr setup but just changed router and needed to setup dvr again as I had it working before
