TheGrimKeeper 30 Posted December 13, 2021 Posted December 13, 2021 So I just added a TV cartoon series from DVD. The cartoons are 12 minutes each, but on the DVD they're packaged as 30-minute episodes featuring two cartoons each. TVDB has the correct DVD order, so I ripped and named them according to those names and order. I scanned them into my library, and of course it came up as Aired order. So in metadata manager I changed the Order option to DVD, rescanned, and...nothing changed. How is this supposed to work? 1
GrimReaper 4919 Posted December 13, 2021 Posted December 13, 2021 4 hours ago, TheGrimKeeper said: in metadata manager I changed the Order option to DVD, rescanned, and...nothing changed Metadata Refresh is needed. Also, TVDB must be first meta-provider in library settings. 1 1
TheGrimKeeper 30 Posted December 13, 2021 Author Posted December 13, 2021 1 hour ago, GrimReaper said: Metadata Refresh is needed Thanks, I'll give that a try. I appreciate the advice! 1
ciisubstance 4 Posted September 26, 2022 Posted September 26, 2022 Thanks, didn't know about "DVD order" in metadata manager, helped me. 1
ndfan77 6 Posted March 13, 2024 Posted March 13, 2024 (edited) Is there a way to set DVD order for the whole library? Guessing there isn't unless I somehow missed it. If there actually isn't a way to set DVD order for a library, this would be a good improvement to add. Edited March 13, 2024 by ndfan77
Luke 42260 Posted March 13, 2024 Posted March 13, 2024 54 minutes ago, ndfan77 said: Is there a way to set DVD order for the whole library? Guessing there isn't unless I somehow missed it. If there actually isn't a way to set DVD order for a library, this would be a good improvement to add. HI, there currently isn't, although it's not a bad idea.
lolotux 4 Posted January 23, 2025 Posted January 23, 2025 Ok metadatamanager After that click refresh metadata with thetvdb in all first place.... in server admin - librairy But the order doesn't change or I mssed something! Sorry for my english, a french man ;)
Happy2Play 9814 Posted January 23, 2025 Posted January 23, 2025 6 minutes ago, lolotux said: Ok metadatamanager After that click refresh metadata with thetvdb in all first place.... in server admin - librairy But the order doesn't change or I mssed something! Sorry for my english, a french man What do you mean the order doesn't change?
Happy2Play 9814 Posted January 23, 2025 Posted January 23, 2025 8 minutes ago, lolotux said: Ok metadatamanager After that click refresh metadata with thetvdb in all first place.... in server admin - librairy But the order doesn't change or I mssed something! Sorry for my english, a french man Aired order DVD order As you can see they changed and is physically wrong for my media.
pwhodges 2037 Posted January 28, 2025 Posted January 28, 2025 On 23/01/2025 at 21:51, lolotux said: But the order doesn't change or I missed something! Did you rename the files to use the DVD order episode numbers? Paul
