Chiefmas 40 Posted December 11, 2021 Posted December 11, 2021 Is there a way to enforce a no-autoplay option or push it as a default setting to clients? Or the "Are you still watching" as a force setting would be great. I'm specifically desiring it for Apple TV, I don't have one but I suspect the default settings are with autoplay enabled. Walking my all my users through all the different clients would be annoying, and I don't trust them not to change the setting, and I don't want them to be able to let it play forever without interaction, because frankly, they probably will. Thanks!
Luke 42186 Posted December 13, 2021 Posted December 13, 2021 Quote Or the "Are you still watching" as a force setting would be great. Hi, I expect this is something that we may have in future updates as it has come up before. Thanks for the feedback.
slicedmass 6 Posted February 3, 2023 Posted February 3, 2023 @Luke is there any plan to implement this feature soon? Optimally I would love to be able to force it to all users where it asks if you're still watching at the start of the 4th episode. Then if they say yes, 3 more will play and on the subsequent episode it asks again.
Luke 42186 Posted February 4, 2023 Posted February 4, 2023 Have you explored the ability to edit some preferences of other users from admin user management?
Happy2Play 9800 Posted February 4, 2023 Posted February 4, 2023 2 minutes ago, Luke said: Have you explored the ability to edit some preferences of other users from admin user management? But isn't that a per client setting?
slicedmass 6 Posted February 4, 2023 Posted February 4, 2023 (edited) Yes I have, seems to be per client or something. Edit: I would love to see a global setting to either force Emby to not play the next episode or to ask for user input after 3 episodes of a show. Edited February 4, 2023 by slicedmass
Luke 42186 Posted February 21, 2023 Posted February 21, 2023 On 2/3/2023 at 8:30 PM, Happy2Play said: But isn't that a per client setting? No, it's a user profile setting, so it should carry across devices for that user.
