MrVoid21 1 Posted December 11, 2021 Posted December 11, 2021 (edited) It's very sad to see that opus wont direct play on lg tvs,even though it is supported.Is there any hope this very popular codec will be supported in a future update? Edited December 11, 2021 by MrVoid21
SamES 1084 Posted December 11, 2021 Posted December 11, 2021 Try playing the file with opus from a usb drive connected direct to the tv and use the TV’s internal media player app. Please report back whether the audio plays as expected. Just be aware that if there are multiple audio tracks and the selected track is not playable (ie: the opus track) the LG tv will automatically try the next tracks until it finds one that’s playable.
MrVoid21 1 Posted December 12, 2021 Author Posted December 12, 2021 It plays just fine.it recognizes the audio,i can send a pic.The audio plays like any other audio.It is supported.I have many movies that have opus audio,and i think that many others do.Can you please add it to an updat
SamES 1084 Posted December 12, 2021 Posted December 12, 2021 There's been a few changes since the last release, so I have feeling the correct Opus support is in there for the next release already. If you want to PM me a link to a test file to confirm I can try it for you in case it's a format that we've missed previously
MrVoid21 1 Posted December 13, 2021 Author Posted December 13, 2021 I don't think i understand.Are you referring to "last release" as the release that emby has on lg tvs rn,1.024?Is there a new update coming soon?
SamES 1084 Posted December 13, 2021 Posted December 13, 2021 I mean for the next release whenever it is available in the future.
MrVoid21 1 Posted December 13, 2021 Author Posted December 13, 2021 Hopefully it's in the near future
MrVoid21 1 Posted December 13, 2021 Author Posted December 13, 2021 There are also a few glitches within the app,hopefully they get fixed with the new update too.I also wanted to ask one more question,What renderer for .ass subtitles does emby use for their webos client?
Luke 42237 Posted December 14, 2021 Posted December 14, 2021 3 hours ago, MrVoid21 said: There are also a few glitches within the app,hopefully they get fixed with the new update too.I also wanted to ask one more question,What renderer for .ass subtitles does emby use for their webos client? The current release version uses libjass.
MrVoid21 1 Posted December 14, 2021 Author Posted December 14, 2021 Thank you very much for the response.I see that libjass is dead.If possible,can you use SubtitleOctopus as the renderer in the next release?Thanks.
