steve1977 67 Posted September 13, 2014 Posted September 13, 2014 XBMC has a feature to act as UPnP receiver. Was hoping that I can stream to it using the play-to function from MBS. I somehow remember someone in this forum has succeeded doing so? Any advice how to make it happen? XBMC already shows up in the list of play-to devices, but the stream does not start when starting to play a movie.
Spaceboy 2573 Posted September 13, 2014 Posted September 13, 2014 Works for me with raspbmc with xbmb3c. I switched on everything in network. Appears as a dolma device Sent from my iPhone using Tapatalk
steve1977 67 Posted September 13, 2014 Author Posted September 13, 2014 Works for me with raspbmc with xbmb3c. I switched on everything in network. Appears as a dolma device Sent from my iPhone using Tapatalk Also appears for me as DLNA device, but it fails to play. Does this work for you and did you create a dedicated profile?
Spaceboy 2573 Posted September 13, 2014 Posted September 13, 2014 Created a profile but just copied the default and used the user-agent I got from the log. I posted it elsewhere, give us a sec Sent from my iPhone using Tapatalk
Spaceboy 2573 Posted September 13, 2014 Posted September 13, 2014 Ok seems I didn't even need to set a user agent. I've recently been using it to play music over dlna, previously I used xmb3c as the remote player for video. It worked, but I'm having other trouble with that one do not used for a while Sent from my iPhone using Tapatalk
Luke 42238 Posted September 13, 2014 Posted September 13, 2014 you will need a profile because the default transcodes just about everything. basing it off the wdtv live one is a good start. please post the profile here and it can be included in a future server release 1
Spaceboy 2573 Posted September 13, 2014 Posted September 13, 2014 Can have a look at this tomorrow, would you mind giving me some advice on why I can't get the sonos profile to work @@Luke? I've been trying with happy2play but seem to have hit a brick wall. Cheers Sent from my iPhone using Tapatalk 1
steve1977 67 Posted September 19, 2014 Author Posted September 19, 2014 Thanks. Did you have a chance to look into this?
Spaceboy 2573 Posted September 19, 2014 Posted September 19, 2014 its all setup but as with the Sonos profile MBS is not connecting the profile and the device. I can't get past this without the help I asked for. still trying myself though
steve1977 67 Posted September 20, 2014 Author Posted September 20, 2014 Thanks. Appears you are a step further figuring it out. Hope Luke can share some guidance what you will have to do to have MBS match device and profile. @@Luke
Spaceboy 2573 Posted September 25, 2014 Posted September 25, 2014 definitely needs more detail. it plays to but no progress is reported by mb3, no device description is available
Spaceboy 2573 Posted September 25, 2014 Posted September 25, 2014 (edited) works for me, probably still needs some more detail. let me know what and i can make more changes Edited September 26, 2014 by Spaceboy
Happy2Play 9811 Posted September 25, 2014 Posted September 25, 2014 (edited) @@Spaceboy are you sure this actually works with no Identification fields? Could you post the DeviceDescription: section of the log if present. Edited September 25, 2014 by Happy2Play
steve1977 67 Posted September 26, 2014 Author Posted September 26, 2014 Thanks. Is there supposed to be an attachment? How did you get it working?
Spaceboy 2573 Posted September 26, 2014 Posted September 26, 2014 Sorry, there was. happy2play spotted some personal info in there so I deleted. It needs more work anyway, I'll take a look tonight. Not far away though I think Sent from my iPhone using Tapatalk
steve1977 67 Posted September 26, 2014 Author Posted September 26, 2014 Great, looking forward to and will give it a try. Thanks!
Spaceboy 2573 Posted September 27, 2014 Posted September 27, 2014 thats the same, plays back but no info in mbs.
Spaceboy 2573 Posted September 27, 2014 Posted September 27, 2014 so in the log i see this: 2014-09-26 22:54:53.5376 Debug - Dlna: No matching device profile found. The default will need to be used.2014-09-26 22:54:53.5376 Info - Dlna: No matching device profile found. The default will need to be used. DeviceDescription: FriendlyName: Bedroom Manufacturer:Team XBMC ManufacturerUrl:http://xbmc.org/ ModelDescription:XBMC Media Center - Media Renderer ModelName:XBMC Media Center ModelNumber:13.2 Git:20140817-0f3db05 ModelUrl:http://xbmc.org/ SerialNumber:2014-09-26 22:54:53.5376 Info - Dlna: DLNA Session created for Bedroom - XBMC Media Center but replicating it into the profile doesn't change anything. i can play stuff but i get no control over it once its started and no info reported in the server
Spaceboy 2573 Posted September 27, 2014 Posted September 27, 2014 but elsewhere i see this 2014-09-26 23:17:24.7668 Debug - Dlna: No matching device profile found. The default will be used. User-agent: XBMC/13.2 Git:20140817-0f3db05 (Linux; Raspbian GNU/Linux 7 (wheezy); 3.12.21 armv6l; http://xbmc.org).
Happy2Play 9811 Posted September 27, 2014 Posted September 27, 2014 (edited) Try this. <Identification> <FriendlyName /> <ModelNumber /> <SerialNumber /> <ModelName /> <DeviceDescription /> <ModelUrl /> <Manufacturer>Team XBMC</Manufacturer> <ManufacturerUrl>http://xbmc.org</ManufacturerUrl> <Headers> <HttpHeaderInfo name="User-Agent" value="XBMC" match="Substring" /> </Headers> </Identification> DeviceDescription: FriendlyName: Bedroom Manufacturer:Team XBMC ManufacturerUrl:http://xbmc.org/ ModelDescription:XBMC Media Center - Media Renderer ModelName:XBMC Media Center ModelNumber:13.2 Git:20140817-0f3db05 ModelUrl:http://xbmc.org/ SerialNumber: General rule looks in the log if you match this info in a profile it will be found, but at least half the info is specific user input data like "Bedroom" was user input. Not the same on every device. ModelNumber I would guess is the XBMC version, won't be the same for everyone. But for personal use all the info to make it work is listed. Note: even if you have a profile some device have there own already coded. Example the Roku Dlna: No matching device profile found. The default will be used. User-agent: Roku/DVP-5.5 (045.05E00415A) Edited September 26, 2014 by Happy2Play
Spaceboy 2573 Posted September 28, 2014 Posted September 28, 2014 still looking at resolving this for dnla on raspbmc but i should say there is always the option of installing xbmbc3 and playing direct to that. needs no config and you get full control.
Spaceboy 2573 Posted September 28, 2014 Posted September 28, 2014 update, the profile is definitely working. everything plays to raspbmc over dnla (not xbmbc3) and my customisation is respected. the problem is you have no control in mb3. i believe its down to this error: 2014-09-28 16:55:07.5899 Debug - Dlna: Bedroom - Received PlayRequest: PlayNow2014-09-28 16:55:07.6169 Debug - Dlna: Found matching device profile: Raspberry Pi2014-09-28 16:55:07.6219 Debug - Dlna: Bedroom - Playlist created2014-09-28 16:55:07.6219 Debug - Dlna: Bedroom - Playing 1 items2014-09-28 16:55:07.6219 Debug - Dlna: Bedroom - SetAvTransport Uri: http://192.168.1.15:8096/mediabrowser/audio/8164d9f7b71fa4e0f4008ddb6267f330/stream.m4a?Params=8beb92e28ceb4e19013fd98d385b00c1;uuid:43955c9a-0349-a162-fd03-6a757f74cac1;8164d9f7b71fa4e0f4008ddb6267f330;true;;;;;;;;;;;0;;;; DlnaHeaders: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01D00000000000000000000000000000 2014-09-28 16:55:07.6219 Info - App: HttpClientManager POST: http://192.168.1.31:1758/AVTransport/43955c9a-0349-a162-fd03-6a757f74cac1/control.xml2014-09-28 16:55:07.6689 Info - App: HttpClientManager POST: http://192.168.1.31:1758/AVTransport/43955c9a-0349-a162-fd03-6a757f74cac1/control.xml2014-09-28 16:55:07.7160 Info - App: HttpClientManager POST: http://192.168.1.31:1758/AVTransport/43955c9a-0349-a162-fd03-6a757f74cac1/control.xml2014-09-28 16:55:07.7681 Error - Dlna: Error reporting progress Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). System.FormatException at System.Guid.GuidResult.SetFailure(ParseFailureKind failure, String failureMessageID, Object failureMessageFormatArgument, String failureArgumentName, Exception innerException) at System.Guid.TryParseGuidWithDashes(String guidString, GuidResult& result) at System.Guid.TryParseGuid(String g, GuidStyles flags, GuidResult& result) at System.Guid..ctor(String g) at MediaBrowser.Server.Implementations.Session.SessionManager.<OnPlaybackProgress>d__37.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.PlayToController.<_device_PlaybackProgress>d__16.MoveNext() here we can see it sucesfully playing an alac file and it erroring on the progress back from raspbmc. this is the same as reported here http://mediabrowser.tv/community/index.php?/topic/9276-dlna-error-reporting-progress/ so i think more guidance is needed at this stage. cheers
Happy2Play 9811 Posted September 28, 2014 Posted September 28, 2014 @Luke - Does the DLNA Play to media progress come from the profile or the server?
Luke 42238 Posted September 28, 2014 Posted September 28, 2014 i'm not sure what exactly you're asking, but basically what's happening there is after playing something, we query the device to find out what it's doing, and the media Id it's giving us isn't matching what we've sent it. why still needs to be determined.
steve1977 67 Posted September 29, 2014 Author Posted September 29, 2014 I am a bit lost. Are you saying that I can just install XBMC3C and then play-to via dlna will work? If that's the case, it should be easy for xnappo also to get the "normal" dlna working?
